Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-09-2004, 05:50 AM   #1
marksr
CF Member
marksr's Avatar
Default Garage Ramp Maximum Incline Angle
Good Morning. I have a 2004 C5 and just bought a 2-car garage for it.
The floor of the garage is 8.5 inches above street level.
Being a better driver than carpenter, can anyone suggest how long a ramp should be to allow driving into the garage without scraping the spoiler? I plan to build the ramp from pressure treated lumber.
Thanks.
marksr is offline   Reply With Quote
Old 09-09-2004, 10:53 AM   #2
tT-REXXX
CF Senior Member
tT-REXXX's Avatar
Default scrape
Just for the record the spoiler was designed to be scraped a little,but 8'' is a lot
tT-REXXX is offline   Reply With Quote
Old 09-09-2004, 11:06 AM   #3
srchief100
CF Senior Member
srchief100's Avatar
Follow the guidelines for wheelchair/handicap access.
srchief100 is offline   Reply With Quote
Old 09-09-2004, 11:15 AM   #4
Evil-Twin
CF Senior Member
St. Jude Donor '03-'04
Evil-Twin's Avatar
Thanks.
27 inches long @ 17* degree angle.
Evil-Twin is offline   Reply With Quote
Old 09-09-2004, 11:50 AM   #5
Mike Mercury
CF Senior Member
Mike Mercury's Avatar
you can look at my ramp design:
http://mikemercury.home.att.net/ramp.htm
My 2002 non-lowered non-Z51 coupe could only tolerate a 9 degree rise to avoid touching the rubber air blade. Once the car was tilted 4 inches high in front , the angle could increase to 15 degrees.
That;s why I did two angles on these ramps. If I maintained the 9 degree angle of rise, the ramps would of needed be (around) 8 feet long to get the desired 10" lift. By changing to 15 degree at the 4 inch lift mark, I cut down on the overall length of the ramp.
Like others stated, making contact with the flexible air dirverter is not a negative thing... it's made to flex.
Mike Mercury is offline   Reply With Quote
Old 09-09-2004, 12:53 PM   #6
marksr
CF Member
marksr's Avatar
Thanks everyone for the input.
Since I am custom building these, I want to avoid the need to have the spoiler use it's hinge.
The dual angle design looks good, but since I will be using these to enter a garage the rear wheels will be following the same path. I am concerned about mid-chassis hang-up if the front wheel are going level before the rear wheels get enough incline to clear the "hump" where the ramp stops inclining and becomes level.
Anyone ever do this or design it?
Old 09-09-2004, 01:36 PM   #7
George V
CF Senior Member
My garage has 2 levels 12 inches different in elevation, my concrete ramp is 12 feet and I donít come close to hitting anything. So a inch per foot and your in, no worries
George V is offline   Reply With Quote
Old 09-09-2004, 03:14 PM   #8
T's
CF Senior Member
Cruise-In VII Veteran
St. Jude Donor '06-'07-'08
T's's Avatar
Thanks, love the ramps, hope to build this weekend !
T's is offline   Reply With Quote
Old 09-15-2004, 06:21 PM   #9
marksr
CF Member
marksr's Avatar
Default Final Product Garage Ramps
This is how the ramps worked out. The 1 foot per inch of rise was the trick. I have no less than 2 inches of body clearance at anytime. These ramps worked out to be 8 feet long for the 8 inches of elevation to the floor of the garage.
http://www.erols.com/marksr/garageramp.jpg
Old 09-15-2004, 07:55 PM   #10
Mike Mercury
CF Senior Member
WOW; nice work. Looks professional.
Old 09-15-2004, 10:56 PM   #11
Adrian-S
CF Senior Member
Adrian-S's Avatar
Looks nice, but I'm just curious; If you built the garage knowing you would be parking cars inside, why wouldn't you build the ramp into the equation with the asphalt instead of the wood? (or potentially having the building match up with the current asphalt)
Either way, still a nice setup.
Adrian-S is offline   Reply With Quote
Old 09-16-2004, 05:28 AM   #12
marksr
CF Member
marksr's Avatar
The space I put the garage was already asphalt. It is really a double shed and does not attach to the ground but rather just sits on top. I save on property taxes that way.
Reload this Page Garage Ramp Maximum Incline Angle
Tags
angle, build, c5, car, corvette, design, garage, high, incline, maximum, mercury, mike, ramp, ramps, scraping
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
