Problem message in DIC????? Help!!!
Old 09-08-2004, 09:29 AM
bradleyls103
bradleyls103's Avatar
Default Problem message in DIC????? Help!!!
This morning I got into my 2003 Corvette. when I started the car the DIC said "Charge System Fault" for a few seconds and then went away. My volt gauge was reading around 14 like normal, and as I drove to work it stayed between 13.6 to 14.1 Like Normal????? The car seems to be fine. What does that mean???
Old 09-08-2004, 10:12 AM
INTRUBL
INTRUBL's Avatar
It usually happens to me when I let it sit for a while, I would not worry.
Old 09-08-2004, 11:41 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
HA!
Believe it or not you're being warned the Delco battery is about to fail, possibly leaving you stranded, certainly causing you embarrassment and/or inconvenience.
Was getting the same error code on my '03.
Made a decision after it happened 2-3 times that instead of having Chevrolet replace the battery with the same defective garbage?
I'd just bite the bullet & replace the thing now before a failure, and do so with a battery of my own choosing.
That meant just one thing, Optima Red Top.
Shockingly I haven't thrown that code again, since.
Old 09-08-2004, 11:43 AM
vettexan
vettexan's Avatar
I had the same problem with my 2003. Does it seem like it is not starting right up? Almost like a hesitation when you turn the key? The dealer put in a new alternator under warranty - still showed same message for about a week even though it was starting better. I took it back and they said that it was showing false readings and should go away. They said that nothing was showing on the computer. It did go away and I have not seen the message since.
BTW - A new battery was installed about 6 months ago. Original died with no warning.
Old 09-08-2004, 12:18 PM
yellowvette837
yellowvette837's Avatar
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
Mine does this often. Even after a new Battery!
To Problem message in DIC????? Help!!!
Quick Reply: Problem message in DIC????? Help!!!
