spray paint-interior
Hi guys, does any catalog sell a spray paint to do the center console and other interior plastic parts? Is there a protective coating that goes over that painted part? Thanks
Personally I paint plastic with either SEM plastic paint or with base coat/clear coat autobody paint. SEM is available in a spray can from your local autobody supply shop. There is also a paint from Krylon called Fusion. It is made from plastic and is supposed to work very well. I have not used it so I can't say. I will tell you this make sure you clean all the plastic parts very well. If there is any residue from Armor All or another product it will fish eye the paint and cause poor adhesion. I put plastic parts in my dishwasher if they fit. If they don't I use denatured alchol several times.
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I agree with the above. Good advice!! I use Krylon for painting and have had great results with it. There is one thing though that is that the console gets pretty hot and might not do so well getting painted. That's my opinion though others here hopefully will chime in and give you more tips.
Is this what you are looking for?
http://www.madvet.com/shop?frame=1.58.3474
paint
Received 19,209 Likes
'20-'21-'22-'23-'24
Some of the vendors sell interior paint. This may work well. I believe the key is to get the parts as clean as you can before trying the paint. Good luck - let us know how it turns out if you decide to do this.
Originally Posted by stuart
Tim Burke sanded prepped and painted with exterior Quicksilver and clearcoated...
Originally Posted by ANI
so this was done with exterior paint?. everything that i have been researching all say dont use a paint /but use a dye. for paint that looks great. thats just want i want to do is the console area. i have a couple of bids on console parts if i can get them cheap enough i/ll try it on them and see how they come out. this way if i mess them up i still have mine thanks for all the info
The vinyl dye is a flat finish and you need to wash the piece with dawn, then clean with denaytrd alcohol, once it is clean the dye does bond well. If you want a high gloss finish I suggest the same cleaning, then hit it lightly with 800 or even 1200 wet or dry paper to set some tooth to it. Then I would suggest Krylon for plastic spray paint, no primer need and it bonds well. I have had regular spray paints peel like sunburn from the interior plastic so be careful with them.
Thanks for all the replys and those pics looked sweet. Doug
I had mine done with auto paints...use a plastic adhesion promoter or it will flake off...
Once done, it looked great, high gloss, and no grain. SEM vinyl sprays work alright, but it's just not the same...
