How do you touch up small area with spray paint?
Old 08-14-2004, 10:03 AM
rbl
rbl's Avatar
Default How do you touch up small area with spray paint?
I have a scratch that I need to touch up. I tried the tube paint and it is not good. I now have factory spray paint and clear coat. How do you go about this?
Do you mask off a large area … sand it …. paint it …. or??
Step by step procedure to follow is??
Old 08-14-2004, 10:13 AM
sxeC7
sxeC7's Avatar
St. Jude Donor '06-'07-'09-'10
There have been several threads on touching up scratches by masking them and filling them with brushed on paint. I be leery of spraying a scratch. Your best bet is to go to a shop that specializes in scratch repair.
Old 08-14-2004, 10:23 AM
Mike Mercury
Mike Mercury's Avatar
yes.
there are "scratch repair" businesses that mainly do work for used car dealerships. These specialists can work miracles in little time, for little money. Plus, they'll come to wherever your car is.
Old 08-14-2004, 10:25 AM
rbl
rbl's Avatar
Had not thought of that ... thanks for the tip!
Old 08-14-2004, 09:48 PM
Len16
Support Corvetteforum!
Len16's Avatar
Get a small bottle of touch up paint.
Get a book of matches. Pull out one match. Dip the torn end of the match in the paint to get a small amount of paint on the match.
Carefully (use two hands) use the match to place a small amount of paint in the scratch. Repeat if necessary.
This is not difficult and it works. I've fixed several scratches and chips on my 2000 Silver Corvette (and on previous Corvettes).
Old 08-14-2004, 10:18 PM
SlumpinC5
SlumpinC5's Avatar
Check out this place... http://www.langka.com/
Old 08-14-2004, 10:43 PM
DavesC5
DavesC5's Avatar
I have used it and it does a great job. Just take your time and don't rush the job.
Old 08-14-2004, 10:50 PM
Cocked and Locked
Cocked and Locked's Avatar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Thanks for the info. I will try this.
To How do you touch up small area with spray paint?
Quick Reply: How do you touch up small area with spray paint?
