Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-15-2004, 12:13 AM   #1
Rob 99
I'm "Apache" a psycho dog
Support Corvetteforum!
Rob 99's Avatar
Default Water leak around door sill area
During heavy rain over the last 3 days the front drivers side footwell area is soaked, and i noticed that when i open the door water is puddled up on the sill area, not sure if the water is tracking over the plastic colored trim piece or underneath to the interior carpet.
I actually think its coming in from the door/fender gap (starting right behind the mirror) and running down to the sill, because the car was parked during a heavy t-storm and the water puddled again.
Anyone experience this problem. :mad
Rob 99 is offline   Reply With Quote
Old 07-15-2004, 12:53 AM   #2
Cool 50th AE
CF Senior Member
Cool 50th AE's Avatar
I have water pouring in from the passenger window on my vert. It rained bucket loads on Monday and today. The carpet and passenger seat was drenched with water both days. I had brought it in for service to have the window adjusted under warranty and they said they took care of it. The funny thing was that they worked on the wrong window. When I bring it back I'll put a post-it note on the correct window to be fixed.
__________________
2009 SL550 Benz
My old Vettes
2007 AO Vert
2005 Vert
2003 AE Vert
It represents my belief in personal freedom and my sense of individuality.
Cool 50th AE is offline   Reply With Quote
Old 07-15-2004, 02:14 AM   #3
Rob 99
Rob 99's Avatar
yea water leaks are tough ones, and can do a lot of damage.
I have seen a aux door seal that west coast corvettes sells in there catolog, i wonder if that might fix my leak.
Old 07-15-2004, 02:18 AM   #4
bobsY2Kvette
CF Senior Member
bobsY2Kvette's Avatar
In a word.....Nope
bobsY2Kvette is offline   Reply With Quote
Old 07-15-2004, 04:45 AM   #5
eddie44
CF Senior Member
St. Jude Donor '03
eddie44's Avatar
Are you sure it's a leak? Same symptoms as the dreaded A/C drain plugged scenerio. Your A/C takes humidity out of the air and the drain will practically run like a hose on a rainy day. I had a Pontiac and everytime it rained the passenger side footwell filled up. Turned out the drain on that side was plugged causing the A/C unit to fill up and drain over there. Just a thought before you do alot of damage chasing a phantom door seal problem. Especially if you have owned the vehicle awhile and just noticed the problem. My .02!
eddie44 is offline   Reply With Quote
Old 07-15-2004, 12:33 PM   #6
BigJoe
CF Senior Member
BigJoe's Avatar
Water in the sill area is normal and there is no easy way to eliminate it altogether. But, that's where it should stay. I doubt it would be migrating from there into the driver's side floor, especially when parked, unless you have a hole somewhere. Next time it rains hard (or have someone spray a hose on it), sit in the car and see if you can see the leak.
__________________
2014 Lime Rock Green/Kalahari 3LT Coupe
Forum Member since 6/4/2000
Previous Vettes: 1970 Green convertible, 2000 DBGM Coupe, 2003 QS Z06, 2004 CE Coupe, 2004 MSG Coupe, 2005 AW Coupe and 2012 VY GS coupe.
BigJoe is offline   Reply With Quote
Old 07-15-2004, 12:38 PM   #7
Rob 99
Rob 99's Avatar
Yea I looked at the pic of the door sill, and it runs at the outer door edge, and thats not going to work, as far as it might be the A/C i would say no cause it's only on the drivers side and i see puddling on the door sill. So i think it's running down from the door hinge area and settling in the sill and leaking over or under the plastic trim onto the carpet. Now whats the fix? that is the question?
Reload this Page Water leak around door sill area
Tags
04, 2004, c3, c4, c5, corvette, door, leak, leaking, leaks, plate, repair, seal, sill, sl550, water, z06
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C6 PARTS & TECH NEWS 09-02-05 NEW INFORMATION CorvettePartsBob Ken's Newsletters 12 12-04-2005 12:59 PM
things to look for when buying a c4 lange C4 General Discussion 19 08-06-2005 01:29 PM
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 11:23 AM
How to turn my sieve of a C5 into a water tight drum? C5Noir C5 Tech 12 12-30-2002 07:04 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
