Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 General
General C5 Corvette Discussion not covered in Tech Sponsored by
Bud's Chevy
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-09-2004, 09:50 PM   #1
Coolaid
CF Senior Member
Coolaid's Avatar
Send a message via AIM to Coolaid Send a message via Yahoo to Coolaid
Default ???Changing the blinker/running light bulb???
My front passenger running light is burnt out and I need to change it...How do I do this? I can't access it from under the hood or under the front bumper...The lens seems to hinge back slightly, but I don't see how to get to the bulb. What the heck...Am I stupid?
Coolaid is offline   Reply With Quote
Old 07-09-2004, 10:03 PM   #2
VETLAGD
CF Senior Member
St. Jude Donor '06
VETLAGD's Avatar
Send a message via MSN to VETLAGD Send a message via Yahoo to VETLAGD
I hope your not stupid, because if you are then so am I because I have got the EXACT same problem. I will be watching this post closely...
VETLAGD is offline   Reply With Quote
Old 07-09-2004, 10:29 PM   #3
sebringsilver97coupe
CF Senior Member
sebringsilver97coupe's Avatar
Send a message via AIM to sebringsilver97coupe
from what ive heard u can get to it from the top side by going under the headlamp. personally, wehn i did mine i did the hard way and took off the close put panel under the frt bumper and went in that way. but many people say u can get to it from the top. i know i just changed my fog lamp bulbs to superwhites from the top side, 30 seconds per side. was very easy. should be fairly similar since they are in almost same spot.
__________________
1997 C5 sebring silver auto. y2k chromies, slotted/drilled rotors, xm, slp, clear euros etc etc
2005 chrysler sebring touring navy metallic
2006 chevrolet silverado silver birch
1996 dodge neon metallic green
2006 starcraft 1700 sport (boat) canary yellow/white
sebringsilver97coupe is offline   Reply With Quote
Old 07-10-2004, 01:23 AM   #4
Tim2K4Vert
CF Senior Member
Tim2K4Vert's Avatar
Just drive the car up on some ramps (or jack up the front end) and remove the bottom access panel. Once that's removed, you can just push the brake duct out of the way and have easy access to all bulbs. Trying to come in from the top through the headlight area is a PIA unless you have skinny arms.
__________________
"Formal education will earn you a living. Self education will earn you a fortune."
- Jim Rohn
Tim2K4Vert is offline   Reply With Quote
Old 07-10-2004, 08:45 AM   #5
navy99vert
CF Senior Member
Cruise-In VIII Veteran
navy99vert's Avatar
Move the brake duct to the side and if you can fit your hand in the hole the blinker in right there. That is how I changed mine GOOD LUCK
navy99vert is offline   Reply With Quote
Old 07-10-2004, 09:03 AM   #6
C500HP
CF Senior Member
C500HP's Avatar
Quote:
C500HP is offline   Reply With Quote
Old 07-10-2004, 11:50 AM   #7
Coolaid
CF Senior Member
Coolaid's Avatar
Thanks for the info...I will give it a whirl.
Old 07-10-2004, 10:40 PM   #8
Coolaid
CF Senior Member
Coolaid's Avatar
Ahhhhh!!!! That was the biggest PIA!!!! First I turned on my headlights so I could attempt to go in through the top (hood, under the headlight) I am relatively small boned and I got my arm caught!! No big deal...only lost 2 layers of skin trying to get my arm out. I didn't want to bother with taking the panel off, so I went in through the brake duct and that was by far the best way to go. Don't forget you have to press the "tab" on the light bulb housing in order to rotate it and remove it. Thank God I love this car or I would of sold it or pushed it off a cliff after getting my arm caught. :mad :mad
Old 07-24-2004, 04:18 PM   #9
dhobson
Junior Member
I had the same problem, lost 2 layers of skin also. Then I decided to remove the 4 screws holding the black plastic around the headlight. Very easy, short screws. Once they are removed, it a straight shot at the lamp. BUT the bigger question. Why the hell does this lamp keep burning out. I have to make my 3rd replacement. I am starting to think it has something to do with water...
dhobson is offline   Reply With Quote
Old 07-24-2004, 04:25 PM   #10
KonaVette
CF Senior Member
St. Jude Donor '03-'04-'05
Support Corvetteforum!
KonaVette's Avatar
I had one go out on Monday. Went to my guy and he said turn on the lights, so I raised the light and he stuck his hand in and 20 seconds later had the burned out bulb in his hand. I bought another and 15 seconds later it was installed. No skin involved
__________________
98 Black on Black Coupe, fully optioned.
High's in the 80's low's in the 80's driving in Paradise year around.
KonaVette is offline   Reply With Quote
Old 10-20-2004, 12:41 AM   #11
shadow7
Junior Member
Default Easy Way To Change the Bulb
I found a simple way to do this. Push the break duct out of the way and spray your arm with WD-40. Im 225 lbs and this allowed me to easily enter my arm and changed the bulb. I was in and out in about 30 seconds.
Robert
shadow7 is offline   Reply With Quote
Old 10-20-2004, 06:41 AM   #12
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
talon90's Avatar
I used the pound of flesh method too (all right, just two layers as previously mentioned. Get the headlights up using your preferred method by either powering them on or using the *****. I then remove the plastic shroud around the head light assembly, three screws. I then reach in and after a couple of scrapes on the arm and hand I have the bulb socket out. It's not the best or the easiest but probably the fastest for me. I hadn't heard about the brake duct method...I may give that one a shot after reading this thread for my next bulb.
Paul
__________________
NCM Life Member
2005 Precision Red Coupe - Born on 10/04/2004 Adopted 05/26/06
Past Corvettes
1997 TR Coupe. MN6 19I. Born on 04/15/1997
1984 Coupe
And yeah, we wave.
More photos on my site. www.theredlion.us/Redlion2.htm
http://smg.photobucket.com/albums/v610/talon_90th/C6/
and here:
http://photobucket.com/albums/v610/talon_90th/Corvette/
talon90 is offline   Reply With Quote
Old 10-20-2004, 06:50 AM   #13
DeeGee
DeeGee's Avatar
Dave Gledhill David Gledhill
I've done this on a number of occasions.
Pop up the headlights and back off one position to kill the lights
Take off the black plastic housing around the headlight (3 screws). Reach down inside around the headlight unit and the DRL bulbs are easliy accesible. Squeeze the bulb holder to release the spring clip and rotate the unit to release it from the housing (I think its counter clockwise). Its a one handed job so it can be tricky. Change the bulb and reverse to reassemble.
5 minute job - Easy!
DeeGee is offline   Reply With Quote
Old 10-20-2004, 07:17 AM   #14
freemanj
CF Senior Member
freemanj's Avatar
Remember Righty Tighty, Lefty Lossey!
freemanj is offline   Reply With Quote
Old 10-20-2004, 10:40 AM   #15
tT-REXXX
CF Senior Member
tT-REXXX's Avatar
Default price of admission
$100 at dealer.hard to do by yourself
tT-REXXX is offline   Reply With Quote
Old 10-20-2004, 11:32 AM   #16
99C5Alan
CF Senior Member
99C5Alan's Avatar
One thing that has not been mentioned is how to handle the bulbs.
When you handle the new bulb (including taking it out of the package) wear a surgical glove or similar.
As with projector bulbs, these bulbs will burn out faster if handled with bare hands due to the oil on your skin.
99C5Alan is offline   Reply With Quote
Old 10-20-2004, 12:46 PM   #17
atl97vette
CF Senior Member
atl97vette's Avatar
Location: You want HOW much for that Corvette part??? Atlanta GA
atl97vette is offline   Reply With Quote
Reload this Page ???Changing the blinker/running light bulb???
Tags
03, 94s, blinker, bulb, c5, c6, change, changing, corvette, cvorvette, front, frt, light, lights, running, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
