2004 NA 640+hp
The following 4 users liked this post by Mikes-Z06:
Cruising
im currently at 640 before the tune. i did btr stage 1 cam, new headers, had some work done to my heads got tripple springs in there as well, dual intake, double linked chain buch of little stuff and NA pushing over 600 is awesome. theres like no videos anywhere with 600+hp with no superchargers hoping to be close to 700hp to the crank at least before any forced air. car is a screamer. neig=hbors called cops last night lol
vettefordays (03-03-2024)
Cruising
i was kinda asking if anyone else has theirs over 600 with no forced air. no supercharger no turbo. there are 0 youtube videos with 600+hp without the forced air. so it makes it look like you 100% need 1 to get over 600. but its obvisouly not true lol since lots of people have done it i heard on this site.
Cruising
what if i told you all the parts and work i put in the car was cheaper than just 1 forced air system???? i put under 2700 into parts. and still got a NA to 600+hp
Speedy?
With the parts you listed, you're 200+ shy of 640. I don't know how the scan tool measures or what input it requires, but that number is far from accurate. As others have said, a dyno sheet will give you a much more accurate number.
Stroker_9 (02-29-2024)
Cruising
the work on my heads added 90 alone 45 a head tipple springs and some degree wok, not sure that the cam added brt stage 1, headers adding 28 intake adding 30, double linked chain for faster response. the scan tool shows 640 if i run it again ill get a picture of it. ill def post dyno stats. what type of video file is required for this site? wont let me upload any pictures or videos.
