99 convertable rear window blew out in carwash
Hi,Looking to get a plexi-glass replacement for my rear convertable glass window. Glues rarely work to to reatatch glass to top.Im going to drill holes in the plexiglass and rivit or bolt it to the rubber ring where the glass window attached., the rubber ring is very strong and will stop the bolts from ripping the canvas.Brass bolts should look realy good against the black top. Any suggestions?
Popular Reply
01-27-2024, 02:15 PM
The following 6 users liked this post by grinder11:
Dads2kconvertible (01-27-2024),
FLYINBY (01-29-2024),
Klipsch (01-27-2024),
Leo Guggenbiller (01-27-2024),
sonicss33 (02-05-2024),
and 1 others liked this post.
Received 1,218 Likes
Klipsch, having the rear window of my C5 soft top vert become detached, and the use of Rhino glue would only last one season, I considered doing what you are considering using plexi-glass to permanently attach to the soft top. Then I read where others have used 3M Window Weld glue and got good results. So, this past fall I did the 3M procedure that included using the 3M Single Step Primer. So far, the window has held. Since my C5 is outside 24/7/12, the test will be in the summer when the 3M glue is subject to the interior and exterior heat. My chemical engineer neighbor opines that most glues available to the public will degrade after continued heat exposure. If it fails, your fix is next on my list.
Thanks , Ive tested 6 adhesives with no success. Ill give your suggestion a test run, but im just looking for a quick easy fix to last me a couple years till i need new canvas. Noone will see it with the top down and thats usually the only time i drive it.
yellow2007 (01-27-2024)
Hi, I tried that kind of glue on test pieces..the rubber and the glass were so tight air couldnt get in to dry the glue.even overnight. still wet like it was still in the bottle .I had a little better luck with 2 part epoxy but yet that didnt last too long on my test pieces. Probably too smooth..thanks for the video .though.
Received 19,452 Likes
'20-'21-'22-'23-'24
There have been a number of threads posted on this issue in the past and the use of a glue has seemed to work well. A search should turn up some hits, but right now the search feature may not work properly - it is a problem that the forum’s tech staff are working to resolve.
Prop Joe (01-28-2024)
Rhino Glue
I reglued mine bout 4.5 yrs ago. Cant tell it ever came loose. Carwash is a big no-no on the verts. Gotta take ur time, get er clean, take ur time and rig up a way to keep constant pressure on
the glass. I let it cure bout 5 days.
PetrofMII (01-29-2024)
I fixed mine much the same way you did. But I used 3M Window Weld. This was 10 years/52,000 miles ago. Still good. BTW-I have taken my 2000 C5 thru the car wash many times. Some car washes can keep the top brush up, suspended above the convertible top. I've never had a problem. Original 24 yo top, 1 rear window re-glue. I have also found the biggest problem with automatic car washes is how low our cars sit. Not all Corvettes will clear all car wash wheel guides, so use caution......
Why not just buy a new top? 🤔
