C5 led interior
C5 led interior
I am ready to change out my interior lighting to LED. Who can recommend a good LED bulb kit that will include all of the interior lights?
Popular Reply
01-04-2024, 09:37 PM
Contact Vette Lights. I don't see a complete kit on their site but they have every light you need and they are a forum vendor @VetteLights
The following 8 users liked this post by Dads2kconvertible:
C5VetteKing (01-06-2024),
Keev1414 (01-15-2024),
killain (01-04-2024),
Raymond Shartrand (01-04-2024),
Trickskier (01-05-2024),
and 3 others liked this post.
The following 3 users liked this post by killain:
Received 19,435 Likes
'20-'21-'22-'23-'24
Also try Sharp Light Innovations - also a forum vendor. Both come highly recommended.
The following 2 users liked this post by OHRedSled:
Raymond Shartrand (01-05-2024)
C5 Led interior
Thanks for all the great responses for my questions about the LED interior lights. I have a set on order and I will let you know how it turns out after I get them and install them.
thank you everyone for your help.
Received 2,687 Likes
2018 C5 of Year Finalist
Good luck with the install and please post pics post installation. One small piece of advice is to not over bulb the application with super bright LEDs. I added a set to the door switches and they were too bright and basically distracting when driving at night.
You're going to see a huge difference when these LEDs light up your interior!!!
The following 2 users liked this post by C5VetteKing:
douglasjre (01-29-2024),
Raymond Shartrand (01-06-2024)
I can agree here! The LED I installed that illuminates the MPH/KPH display on the gauge cluster is so bright it highlights the Check Engine Light icon! At first I thought I actually had a CEL illuminated, but soon realized I didn't otherwise it would have been brilliantly illuminated. One of these days if and when I have the gauge cluster out again I will remedy that.
C5VetteKing (02-10-2024),
Raymond Shartrand (01-07-2024)
C5, LED interior
Thanks for the advice on the cluster lights and the door lights. The kit that I got is for the map, lights, hood, light, rear, cargo lights, and front foot areas for passenger and driver,& license plate, lights I will take pictures of before and after. 👍🙏
Vader_C5 (01-07-2024)
C5 led interior
I’ve got the interior lights changed out to LED. The rearview mirror lights were the most difficult ones, I just removed the mirror, because it was much easier to work on. The problem I am having is with the under hood LED light. When the lights time out and go off. The LED under hood goes from bright to half power. If I put the halogen light back in when the interior LED lights, go off the under hood light does go off, drawing 0 V. When the LED light goes to half power it’s drawing 5 V. I’m assuming this LED under hood light is not, does not have enough resistance?
yellow2007 (01-09-2024)
Raymond Shartrand (01-09-2024)
C5 led interior.
New underhood light led is not working properly. It started full bright, but when the lights timed out to go off the interior lights, go off, but the under hood light goes to minimum power and is still partially lit. If I close the hood, it goes off, but when I raise it, it goes back to low power. I put the halogen light back in and the under hood light works as it should. When the halogen light shuts off, I measure 0 V across the terminals. When the LED light goes into very dim mode, I measure 5 V across the terminals. I’m guessing it’s the low resistance of the bulb?
C5 led interior
What's the solution if you don't have the festoon bulbs but instead the three color LED thingies? They're not bright and the color sucks. I sure want to change those out
