C7 wheeels on a C5
C7 wheeels on a C5
Will 245 / 35 X 19 front and 305 / 30 X 20 rear wheels and tires from a C7 Z51 fit my C5?
If yes will they require spacers?
If spacers are required what specs?
Night Owl for life
Received 3,255 Likes
I'm running 19/20 c7 zr1 style wheels on my car. It sounds like you're looking for stock width wheels? Do you know the offsets?
Night Owl for life
yes those are c8 wheels
C7 and C8 bolt pattern (5x120mm) are different than C6 and earlier (5x4.75" or 120.65mm). You'll have issues keeping the lug nuts tight, and would need a big adapter / spacer to change the bolt pattern. This is not a good idea.
jackthelad (11-26-2023)
Night Owl for life
^ c7 has same bolt pattern as c6 & c5. it was the c8 that changed patterns
https://www.wheel-size.com/size/chev...corvette/2017/
CHEVROLET CORVETTE C7 [2014 .. 2019]6.2SC
650 hp
- Generation: C7 [2014 .. 2019]
- Production: [2015 .. 2019]
- Sales regions: USA+, Russia+
- Power: 650 hp | 485 kW | 659 PS
- Engine: 6.2 L, LT4, V8 , Petrol
- Trim Levels: Z06
- Center Bore / Hub Bore: 70.3 mm
- Bolt Pattern (PCD): 5x120.65 (5x4.75)
- Wheel Fasteners: Lug nuts
- Thread Size: M12 x 1.5
- Wheel Tightening Torque: 140 Nm
CHEVROLET CORVETTE C7 [2014 .. 2019]6.2I
460 hp- Generation: C7 [2014 .. 2019]
- Production: [2017 .. 2019]
- Power: 460 hp | 343 kW | 466 PS
- Engine: 6.2 L, LT1, V8 , Petrol
- Trim Levels: Grand Sport
The following 3 users liked this post by jdmvette:
I stand corrected- new to the Corvette space, I'm used to Zeta/Alpha cars that have been on 120mm for a while, and thought the C7 was the changeover. C7 wheels on older cars should be fine, C8 is not.
Night Owl for life
