LS3 is bought!
LS3 is bought! / Ready for install
Just purchased an LS3 525hp crate motor from Chevy performance to replace the old and about to expire LS1. Thought about going BluePrint Engines but their lead time was February 2024 at best and this I could get now and got a discount through a contact. Going to have a shop do the install and tune, mainly due to time constraints. Super excited and will post process and dyno numbers once all said and done. Should be much better on the track.
Received 4,169 Likes
I want to see how your tuning goes and the use of the Lingenfelter convertor box.
That particular LS3 is an amazing engine!
Best of luck to you sir!
BACNBLK (01-17-2024)
Received 2,269 Likes
This sounds like a really fun build. Look forward to updates and tire smoke. 😎
Uneducated overachiever
I would like to swap one into my 1965 C10 truck.
Congrats on the LS3, I’ve dreamed of buying the crate engine since 2008!
Running Guns & Moonshine
No need if a shop is doing the work.
LS3 is a great way to go all around. I should think about stacking a one or two in storage somewhere for future projects. Mine would be from the wrecker, mind you.
Fun car when done no matter what. So when are you adding the blower? Costs twice to tune twice....
jjc508520 (12-18-2023)
Received 19,420 Likes
'20-'21-'22-'23-'24
Best of luck to you with the swap.
Yes I will be selling the LS1 but likely not until spring 2024. If interested let me know and I'll PM you when it's ready
Moderator
A centrifugal super charger is a completly different animal . A centrifugal super (which most people would not call a "blower." so I assume you're not talking about this) will run all day without temp issues, for obvious reasons.
there are other reasons not to go with a centrifugal super, but it's a weighing. Some track rats on here will tell you it's more complex and is just another thing that could possibly go. Others run supers with zero issue. Personal preference. But if you're doing it for temp reasons --- that's not really a reason. A well-built centrifugal super will not have heat issues.
__________________
'67 Sting Ray 327/350/4spd Roadster
'00 'vette 6spd vert, AA super, cam: 531RWHP/ 467lb-ft RW TQ -- Dyno Curve Here || C7 Seats || Full leather Interior: Interior Pics Here
'67 Buick wildcat
'18 Grand Cherokee Trackhawk, 817 RWHP/772 RWlb-ft
'88 Cherokee, ZZ6 crate motor, 404 HP/400 lb-ft
MWWarlord (08-25-2023)
if you're talking a "blower" in the true sense (i.e, a roots style supercharger) then I agree-- heat soak is a big problem. The good news is that there are pretty much zero options out there for a roots style supe for the c5 that can sit under the stock hood.
__________________
'67 Buick wildcat
__________________
'67 Buick wildcat
I considered this myself with the 376/480 all through Covid when I couldn't get one.. So I am curious. How are you planning to deal with the F-body style oil pan it ships with, and what are you going to do for exhaust? I was considering snagging some LS7 manifolds and seeing if a shop could fabricate a collector and use the LS7 cats. If this is an off-road car, I imagine it will just be some headers. Also, are you changing the ECU, getting a 58x converter, or just installing a 24x reluctor? I will be watching your thread, as I still may end up doing this.
Exhaust is going to be Speed Engineering 1 7/8" Long Tube headers and their x-pipe kit
Will get going with the LPE 58x to 24x conversion box as I don't really want to open a brand new factory sealed engine to swap out the reluctor wheel. It is also going to get all the misc wire adapters and extenders to make all the sensors work as well as a new fuel pump to feed the beast. Also a good time to change as the original is 21 years old with over 110K miles on it.
