Best Fuel Cleaner
yellow2007 (07-03-2023)
The following 2 users liked this post by Vader_C5:
BmoreRnsDeep (07-03-2023),
douglasjre (07-01-2023)
Received 19,455 Likes
'20-'21-'22-'23-'24
I use Techron - works well in all my cars.
Techron and Marvel Mystery Oil are the only two additives I use in engines.
The Marvel really helped up get a Corvair that sat for 30 years back on the road when it had sticky valves and rings.
The GM cleaner I think is just Techron in another bottle.
fxe82 (07-04-2023)
Received 3,112 Likes
St. Jude Donor '21-'22
Seafoam for crank case or vacuum lines. Techron for the fuel tank. If you put Seafoam in the crank case, make sure you change your oil soon after.
sonicss33 (07-06-2023)
