Best/Safest Wheel Spacers for High Speed
Mini tub and 345's inside the stock fenders, and you will be the star of the cool crowd.
The following 2 users liked this post by itsonlyairandfuel:
jackthelad (05-18-2023),
miami993c297 (05-17-2023)
This is what I'm running on my track car. You do have to replace the studs with longer ones. Never an issue.
https://eibach.com/1060/S90-6-15-033...tte-pro-spacer
heggsc5 (05-18-2023)
Using a 1" spacer will also put additional strain on your wheel bearings, If you go that route I would also change to the C6 06-08 SKF wheel bearings. That is what GM did
BTW, the C8 studs are larger diameter than the 5/6/7 series. Prep for the Z06 and competition use, I guess.
Who cares about the stock fenders...they are easy to find replacements and repaint.
My issue is the mention of running 25mm spacers just to make some wheels fit. Hell no. Buy the proper offset wheels for "high speed".
If all you want to do is park it in a car show parking lot I suppose you can get away with it.
Don't be the laughing stock.
Use the proper way to do stuff! 🤨
i ran spacers for 8 years on rwd bmw.. boy do i miss that car. Never owned a car that handled so well. I ran spacers on a 500 rwhp stang years ago.. never had problems.... im sorry maybe im missing something but i just dont understand why people claim spacers add stress to the hub but going with a wheel with higher offset doesnt? Or at least is never talked about. Can spacers be dangerous? Absolutely.. but if installed properly and you get the correct ones I just never seen an issue with them. Just my opinion ofcourse
MetalMan2 (06-05-2023)
