Wheel Center cap emblems
Dodgeturbpo (04-25-2023)
Sure should be here by end of week hopefully
Dodgeturbpo (04-28-2023)
Those look great! Hopefully mine will be here in next couple days. Did you use soap or something on them until they were centered so they didn’t stick until you had them where you wanted them
Thanks for your help, but the search continues . . .
yellow2007 (04-28-2023)
Thanks, I’ll let you know when mine are done 🍺
#33
3&3/4 inch from curve to tab
#34
#37
Got mine today, will put them on whenever it warms up again. Do you all take the center cap off, if it doesn’t break or do it while it’s on the car. If off how do they pop off. Thanks
#38
Oldtimer
I have a pretty good eye and the caps on my aftermarket wheels are not the friendliest. I got mine on a nice warm day last week and they went on well. Since the vinyl adhesive does not like to be fooled with I lined it up with the backing on, then pulled the backing and went slow.
The following 2 users liked this post by chasboy:
Dodgeturbpo (05-01-2023),
yellow2007 (05-02-2023)
#39
Thanks, I’ll probably just leave the caps on and try to eye it, with a little soap water. Yours look great!
chasboy (05-01-2023)
