how can I get techron into BOTH gas tanks? is there a fuel up method?
What's the sequence to make sure techron gets into both tanks? Having a hard time wrapping my head around this thx
The following 4 users liked this post by Smoken1:
After the left tank is full the turbulence of adding more fuel keeps mixing with what's in left tank already and spills over to the right tank via the cross over tube
The following 2 users liked this post by Smoken1:
grinder11 (02-20-2023),
yellow2007 (02-20-2023)
knewblewkorvette (02-20-2023)
IMO, if you use one of the Top Tier rated fuels, addition of Techron is unnecessary. The Top Tier rated gasolines already have additional fuel additives provided by Techron. Many manufacturers "recommend'" the usage of Top Tier rated gasolines, the Genesis G80 I previously owned required the usage of Top Tier fuels in order to satisfy the manufacturer's warranty requirements.
Just my opinion, based upon a bit of review of the development history of the Top Tier certification.
Received 3,112 Likes
St. Jude Donor '21-'22
I usually wait until my tank is close to empty, but a 1/4 tank will certainly do. Techron certainly works. I use a bottle or 2 per year.
The following 2 users liked this post by grinder11:
Johnny Hardcore (02-21-2023),
sonicss33 (02-20-2023)
The following 2 users liked this post by Black_Valkyrie:
redzg (02-20-2023),
SouthernSon (02-21-2023)
I would think if one drove to 1/4 tank, which would be all gas in the left tank, then put in half a bottle of Techron, followed by 6 gallons of gas, the left tank would now be a combination of fresh fuel and Techron. Adding additional Techron at this point would transfer over to the right hand tank, followed by the next 8 or so gallons of fresh gas would result in both tanks being a good combination.
Two thousand five hundred of dallars is quite a bit more than 40 or 50 buck repair don't ya know!
Received 4,169 Likes
The following 3 users liked this post by Mr. Black:
Just my opinion. If you are already experiencing fuel indication problems Techron will do nothing at all or just be a band aid. I wasted a few dollars trying this snake oil only to be disappointed.
The fix was fixing it properly.
