View Poll Results: Pick your favorite
Mr. Black
12
12.37%
Kubs
3
3.09%
MSG C5
12
12.37%
tommypenguin
13
13.40%
PerryKing
3
3.09%
JohnnyDee
3
3.09%
Jason Blue Boost
16
16.49%
57gman
2
2.06%
Bandit 00C5
31
31.96%
Route99
2
2.06%
Voters: 97. You may not vote on this poll
2022 C5 of the Year (Modified) - You decide
Received 1,312 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
The 2022 finalists in the Corvetteforum C5 of the Year – Modified competition are listed below. You will decide the winner based on your votes in the poll associated with this thread. The voting will end at 7:30 p.m. EDT, Oct. 20.
The reward in each of the categories is bragging rights and a designation under your user ID declaring your winning status.
The winner will become eligible to participate in the 2023 Corvette of the Year competition with the winners in other Corvette generations.
Link to entry thread, which may include additional pictures on some entries:
https://www.corvetteforum.com/forums...enter-now.html
Mr. Black
AMS Racing Forged 408 LS, LS3 823 Cylinder Heads, LSA Supercharger Approximately 12 PSI, Summit Ghost Cam AKA Stage 1 Turbo Cam, BTR Pushrods, PAC Valve Springs, Innovators West 10% OD Balancer, 8 Rib Accessory and Supercharger Belt drive, Speed Engineering Long Tubes, Custom Mid Pipe with Bassani X pipe, Corsa Sport Axleback, Monster Twin Disc Clutch, JD Corvette 3.5 inch Cowl Hood, G-Stream Duckbill Spoiler.
Kubs
2003 Z06 setup for road course time trial competition, Stock LS6, TPiS 90mm LS6 intake, ARH 1-3/4" headers, no cats, Borla Stinger mufflers, Vi-King Performance Crusader double adjustable shocks, Van Steel delrin bushings, Van Steel 35mm front 25.4mm rear adjustable sway bars, AMT camber kit, engine mount, and diff mount, Wilwood Aero 6 front calipers, Apex Race Parts 18x11 square or 18x12.5 square VS-5RS wheels
MSG C5
Bunch of performance and other go-fast stuff you can't see in the pics.
tommypenguin
Boosted 01 C5.
PerryKing
2001 Coupe - Pewter Metallic, 6 speed, Trick Flow 215 GenX CNCd Heads, Harland Sharp 1.7 roller rockers, TSP 228R cam 228/228 .600/.600 114 LSA, TSP dual valve springs w/ titanium retainers, LS7 lifters, LS2 timing chain, Melling high volume oil pump, ARP head boltsm ARP Crank bolt, ARP Water Pump Bolts, ARP Header bolts, ATI Super Damper, Borla axle back exhaust, TSP 1 3/4 long tube headers, TSP off-road catless X pipe, Mighty Mouse catch can, Blackwing CAI, Alpine ILX-w650 double din receiver XM, Rockford Fosgate P1000x5 Amp, 2 RF P3SD2-8 8” shallow subs(doors), 2 RF P132 3.5” full range(doors), 2 RF T1650 6.5” full range (rear), 1 RF P3SD2-10 10” shallow sub (rear), Kilmat sound mat (firewall to tail lights), Color matched center console (Pewter), Lloyds mats (Corvette Racing), LED interior bulbs, LED red tail light bulbs, Tinted OEM taillight housings, LED smoked rear side markers, Front smoked DRL/turn w/ switchback LED, MGW short throw shifter, Anti Venom Mod (1 washer), BC Racing BR Series Coilovers, AFE adjustable end links, Hotchkis 2285 Front/Rear sway bars, Cray Eagle 18x9 +50 (front), Cray Eagle 19x10.5 +69 (rear), Hankook Ventus V12 evo2 265/35 (front), Hankook Ventus V12 evo2 305/30 (rear), 1/4” rear wheel spacers, KnightDrive TV Low rise LED headlight kit, Optima Yellow Top Battery
JohnnyDee
BBS LeMans Wheels, ACS rear spoiler, Flush mount European taillights, Stainless fuel door, Bassani longtube headers w/crossover pipe & hi flow cats, Mallett carbon fiber mufflers, Lunati cam, Hurst shifter, RM racing twin-flow intake w/dual K&N filters, Drilled & slotted rotors w/ceramic pads
Jason Blue Boost
1998 Nassau Blue Lingenfelter Twin Turbo Tigershark, 346 LPE LS6 forged 8.75 compression with LPE GT9 cam (900hp), Silver painted Fast 90 intake and LPE 90 throttle body, Full Tigershark body kit minus chin spoiler with carbon fiber Tigershark hood #1 of 10, HRE LPE Signature Series 18x9.5, 19x12 with LPE minitubm Rod Davis radiator and Setrab oil cooler, Wilwood 6/4 piston calipers with 14” rotors front and rear, powder coated blue calipers & rotor hats, SuperYank 3500 converter with 3.42’s and HD output shaft, RPM 4L65E Level ? Transmission, Harlan 2 step with line lock switches in ash tray area with Eboost 2 controller
Autometer Cobalt wideband and fuel pressure gauges, F45 to F55 magnetic ride conversion without Delphi kit (parts from a wrecked 03 anniversary car with 400 miles), HUD with Export Z06 300km speedometer cluster and bezel rings, Telescopic steering column, memory seats, mirrors, Z51 leaf springs and sway bars (all from wrecked C5’s), Vette Essentials full interior with LPE on headrest and chrome hoops behind seats, LPE floor mats, cargo mat, and fire extinguisher, All interior switches converted to blue LED, foot wells and cargo area are white LEDs, American Hydrocarbon carbon fiber A pillar, windshield cowl, and wiper arms, Fully painted engine plastics with carbonfiber accent pieces, American chrome caps & screw kit, Euro rear Tailights with reverse lights and hazards, laser side markers, 3rd brake light, Sharp Innovations LED front markers lenses, Euro glass headlights with 6000k HID’s, Corsa Daytona Exhaust exclusive from West Coast Corvettes, Bassani X pipe
57gman
Bandit 00C5
2000 coupe with 266,000 miles on original engine. Highlights include ACP World Challenge front end and splitter, Andersen Carbon Fiber Hood, L5 Race Series quarter panels, Silvers Coilovers, C6 Z06 brakes, C7 Corvette seats and shifter, Forgestar F14 wheels, coil pack relocation along with other wiring.
Route99
Except for "minor changes" to the body, paint, wheels, suspension, engine, drivetrain, and interior she is completely stock. Sorta. All the painted engine bay pieces are the same Firethorn Red color (as the smaller stripe, and the interior); the sun just plays with the color intensity.
Mr. Black
Kubs
MSG C5
tommypenguin
Boosted 01 C5.
PerryKing
JohnnyDee
Jason Blue Boost
57gman
Bandit 00C5
Route99
Received 19,391 Likes
'20-'21-'22-'23-'24
Voted - best of luck to all the finalists.
Received 4,734 Likes
Good luck to all of the contestants
The following 2 users liked this post by Noblebro175:
lewislgZ06 (10-13-2022),
Mr. Black (10-12-2022)
Received 4,169 Likes
I'm going to congratulate Bandit early haha.
P.S. I voted for Bandit. The picture and the aesthetics of the car are ON PoinT.
TCFS (10-24-2022)
Tusc (10-14-2022)
The following 2 users liked this post by JayhawkCPA:
GTcruiser007 (10-19-2022),
Jason Blue Boost (10-15-2022)
Received 2,686 Likes
2018 C5 of Year Finalist
Running Guns & Moonshine
I'm not on base to enter until my car is back on it's wheels. How / when do we submit our cars for 2023?
Great set of cars this year, good luck to all of the finalists! Thank you moderators for listening to the members and allowing the additional photos.
The following 2 users liked this post by workmanw:
lewislgZ06 (10-15-2022),
Route99 (10-17-2022)
Tusc (10-14-2022)
NCM Lifetime Member
Congratulations to Bandit 00C5, your selection as 2022 C5 of the Year - Modified. His car now will compete against the winners in other generations for 2023 Corvetteforum Corvette of the Year after the first of the year.
The following 2 users liked this post by savewave:
Burnt C6 (10-26-2022),
CorvetteMike2024 (10-24-2022)
Congrats to Bandit 00C5 & all of the contestants
I love the car. I personally voted for a different car because all competing are truly badass C5s, but this one represents us well. I'm digging the high mileage original engine too.
Hey Fellas,
Thanks to those who voted for my car. There are some really nice cars to pick from and it’s feels pretty special to win. I’ve loved this car for a lot of years and a lot of miles and she still puts a big smile on my face. My best friend and I have done most of the work on it ourselves and this is her first major recognition.
The following 5 users liked this post by Bandit 00C5:
Kubs (10-25-2022),
Mr. Black (10-24-2022),
Noblebro175 (12-15-2022),
workmanw (12-17-2022)
Congrats to Bandit 00C5 and to all the other finalists. All great looking and performing C5s.
Hey Brian,
This is Darryl, I was just cruz'n through the forum and recognized the ride and I just wanted to give you a congrats. I know you and Gary have spent some time on it and it shows buddy. Had to do a double take because the last time I saw it there wasn't any wide body rear quarters on it !! I will shoot a call to you !!....
IMO, a bad result. The winning car, although gorgeous, isn't performance modded nearly enough. If I were to vote on looks, it would be my choice as well.
