Patches tutorial on HID conversion and ACA installation
Hi,
Does anyone have the link to Patches tutorial on ACA projector installation and HID conversion please, can't seem to locate it anywhere.
Thanks, tak06
Thanks, tak06
Mike98SilVert (02-26-2022)
Thanks for that, but it was a tutorial on the installation of the ACA projector on his black C5 as I recall, it showed the removal of the oem headlight assembly and the installation of a new ACA projector and possibly the installation of
HID setup as well.
BTW I'm going to replace the HID's on my C5 with LED'S because I'm having issues with one side not lighting up and it's probably my fault for not integrating the relay harness to provide 12volts directly from the battery, I understand that a relay
harness won't be necessary with LED'S because of the low voltage required with LED'S and now I can remove those temperamental ballasts as well.
Does anyone know if the ACA projectors uses the H9 bulb for the low beams because I'll have to buy the proper LED fitment for that opening.
Thanks!
HID setup as well.
Thanks!
