2004 CE needs Parking/Turn Signal Light Lens rplc w\LEDs
hey guys... so I am finally throwing in the towel on replacing those amber bulbs every other month after 16 years (I'm stubborn that way )
I was going to patch the holes that have burned through the plastic housing but figure I should replace the entire lens housing while I'm at it. Looks like the lens housings can be had for under $200 for the OE looking pair but might go with a newer design, not 100% sure on that yet as I like the look of the OEM lens housing and moreover, I like the look of the OEM lighting with the amber DRLs.
Seems the way most are going are with the switchback setup where the LEDs alternate white\amber and smoked lens or similar but stubborn me would like to stay with the OEM amber\amber colors. Hopefully that makes sense...
that said, has anyone done this to their C5 (OEM color\look) that can point me to a good lens housing and LED setup?
-Mark
ones on top are more OEM'ish from WestCoast $170 pr
the ones with the black are from Ecklers $151 pr
the ones on the bottom are a 'Diamond cut', fancier version of OEM I guess... Ecklers $164 pr (leaning towards these)
-Mark
Night Owl for life
Received 3,256 Likes
Received 19,440 Likes
'20-'21-'22-'23-'24
^ those do look good. You might also check with George at Sharp Light Innovations and see what he may have.
jcgunn (10-30-2021)
Just note that your choice in LED bulb will determine whether the bulb will blink amber/white/amber/white or amber/off/amber/off during turn signal usage. The latter is better imho.
The following 2 users liked this post by MrMcE:
Lil Blue Coupe (10-31-2021),
LWSZ06 (10-31-2021)
I've also been looking into changing mine and those prices you show seem very high. Other members have used Ebay and other sources such as Devo and found lenses around
$50-75.00 just like the ones you show in your thread. BTW there is another active thread on these right now so take a look.
I replaced mine about a month ago. Went with these cheap ones. We’ll see how they hold up.
https://www.ebay.com/itm/Fit-1997-20...-127632-2357-0
The car had switchback DRLs when I bought it. I switched the turn signals to amber LEDs.
really appreciate the feedback guys and my apologies for creating yet another thread on the subject
not wanting to drop more than $100'ish for the project and based on pics online I've narrowed down the turn signal lenses I like as opposed to the 100+ different options out there, LEDs and hyperflash harness. Pretty sure I can do this myself after watching a few YouTube vids... thank goodness for YouTube!
so if I were to pick up these items would I need anything else, am I overlooking anything?
Turn Signal Lens
$53
Hyperflash Harness
$46.50
DRL LEDs
2X Dual Colors 3157 4157NA LED Switchback White Yellow Turn Signal Light Bulbs
$19
Turn Signal Lens
$53
Hyperflash Harness
$46.50
DRL LEDs
$19
something just popped into my head... resistors! I don't think I have resistors, hopefully I can get some quick feedback to confirm that and then a suggestion on how to add it if I do, I guess I was thinking the resistors were in the hyperflash harness but maybe not
good choice, nice looking, hopefully mine will look as good as yours
