Front turn signal lenses
Hi
Looking to replace my front turn signal lenses. I own a 2002 corvette electron blue. Looking for ideas and pictures
The original are still in.
I put a set of these on mine along with both front and rear led lights. When I replaced them the origs were both burnt and cracked due to the heat. If you do go with LEDs you may need a Hyper Flash bypass harness so the signal lights will work properly.
https://www.ebay.com/itm/31212479896...YAAOSwASxhJ-mP
Received 19,439 Likes
'20-'21-'22-'23-'24
Check forum vendors like jwmotorsportsllc.com and sharplightinnovations.com.
Other forum vendors may offer lighting options too.
Night Owl for life
Received 3,256 Likes
These are a new style out
Received 3,112 Likes
St. Jude Donor '21-'22
+1 for Sharp Light innovations
rjwvetttt (10-19-2021)
Supporting Vendor
Sharp Light Innovations:
Complete DRL package includes housings, bulbs, hyperflash harness and includes discounted upgrades.
https://sharplightinnovations.com/sh...pgrade-package
The following 3 users liked this post by TheRadioFlyer:
Is the light of the Amber swoosh shining thru the bottom screen? You should try raising the lenses with some washers and bolts. That’s what I did with my Sharp Innovations led lenses cause the opening for the lenses on the Tigershark fascia are smaller.
Night Owl for life
I took your advice and shimmed them up tonight so that the lower LED portion of the corner lights can be seen and it turned out great!
Thanks for the tip!
Jason Blue Boost (10-20-2021)
Supporting Vendor
No, that is a seperate LED strip that I am using for my DRL & turn signals.
https://youtu.be/5tyVMwBP2tk
Thanks for the tip!
Thanks for the tip!
How much shim was required?
Depo smoked lens black trim shown ($59.95) Running switchback LEDs that were $18
Ed Ramberger (10-23-2021)
Ed Ramberger what bulbs you running?
I got the 194 corner amber LEDs from RadioFlyer.
More pics in this thread https://www.corvetteforum.com/forums...al-lenses.html
I went with these smoked clear housings off Amazon. I also swapped the bulbs with led amber/clear switchbacks
ZMAUTOPARTS For 1997-2004 Chevy Corvette Front Bumper Signal Lights - Smoke
hey guys, so if I were to pick up these items would I need anything else, am I overlooking anything?
Turn Signal Lens
$53
Hyperflash Harness
$46.50
DRL LEDs
2X Dual Colors 3157 4157NA LED Switchback White Yellow Turn Signal Light Bulbs
$19
Turn Signal Lens
$53
Hyperflash Harness
$46.50
DRL LEDs
$19
