[Z06] 275/40-17 - 295/40-18 Tire experience
Since we C5 Z06 guys have limited tire choices I thought I'd share my experiences using the Nitto 555 G2's with +1 sized front and rear.
The tires that came on my 04 Z06 were stock sized Bridgestone RE 760
The new tires are Nitto 555 G2's --> https://www.nittotire.com/passenger-...formance-tire/
- I bought and mounted 275-40-17 fronts and 295-40-18 rears.
- Balanced on Hunter wheel balancer
- 900 miles so far
- Road trip including Tail of Dragon 3x
- Speedo is 3mph slow at 70mph (will have tuner fix)
- High speed.. yes
In my opinion these are a very good value and I give them a solid thumbs up
Car is at stock ride height.. and the bottom three pics are cornering hard on tail of dragon. (never once had a tire rub)
- 900 miles so far
- High speed.. yes
The following 10 users liked this post by wydopnthrtl:
BMEPdoc (07-27-2022),
cdee63 (02-25-2023),
eyekyu (08-30-2022),
Luv2spedup (02-24-2023),
Mr. Black (07-23-2021),
and 5 others liked this post.
- 900 miles so far
- High speed.. yes
- 900 miles so far
- High speed.. yes
Received 1,872 Likes
That tire combo looks good, Rich. Those 555 G2's are decent rubber, also.
wydopnthrtl (07-26-2021)
Thank you for posting this! I've been looking into this size combination since there are some 200tw Falken's available in these sizes.
I was wondering, have you had any adverse effects with traction control and active handling given the 1.6" size difference front to rear?
thank you for posting this! I've been looking into this size combination since there are some 200tw falken's available in these sizes.
Before trying these I read somewhere about a +/- 0.5" tolerance. But it wouldn't make sense for GM to tune out too large of a tire on the Corvette. So I took the chance and it works just fine.
A bit of an update to my experience thus far at about 1200 miles.
The initial turn in feels softer. Both front and rear.. Then at high cornering forces the tires being a bit taller, have every bit of grip and are more forgiving as the edge of slip is not nearly as on/off as the old stock sized ones were.
As long as you don't want to lower the car a lot.. I'd not hesitate to go with these tires and in this size.
thank you .....
wydopnthrtl (03-04-2022)
Oldtimer
The official GM stagger range is .5-1.4” difference. I had a .4 difference on my Z when I had 275/17-40 in front and 295/35-18 in the rear, I felt it was close enough. I think your number is also close enough and a good substitute for unobtanium tire sizes!
TCFS (12-15-2021)
14 months since tire change... no regrets!
what are the stock tire size for your z06? I am a 1st time corvette owner for a few months and need new tires for my 03z06. It currently has 275/40/17 on front and 295/35/18 on rear. Seems like slim pickings on this size combination.
The stock tires were 265/40/17 & 295/35/18. Most gave up trying to find the original front size long ago, that was an unusual tire size. 255/40/17 & 275/40/17 both work well up front.
chasboy (02-24-2023)
cdee63 (02-25-2023)
Had some fun yesterday on a road coarse and a 145+mph blast. Tires stuck great and had zero problems. And it was cold too. It was in the high 30s F.
The guy who was with me tests cars for a living and has spent time on all the tracks. He said "impressive" the first time I cornered hard.
LOL.. approaching one turn he said "you can slow down". I said "no I got it"
The following 2 users liked this post by wydopnthrtl:
greenscobie86 (04-07-2024),
shenny88 (07-21-2023)
Oldtimer
I will say the vararam intake was finally taken full advantage of. That was the first time I've had that much free play w/the vette and honestly I'm surprised at two things.
1. How strongly it was pulling up in 5th gear at 130+
2. How much fuel it used. Holy cow.. at sustained speeds over 120 and 37F temps it was consuming fuel like a thirsty shark.
Received 19,399 Likes
'20-'21-'22-'23-'24
Good info for those with a Z06 and needing to put new tires on their car.
wydopnthrtl (03-27-2023)
Cruising
Thanks for the review.
Wish I saw this earlier. could have saved hours looking at tire sites trying to come up with the right combo of size, performance and price. Ordered the Nitto 555s yesterday from Tire rack, $1000
Supporting Vendor
@wydopnthrtl thank you for the real world review! So much better than book knowledge. Thank you for taking the time to post, and the pics are fantastic!
@Mr.Mike Thank you for your business. We appreciate your support.
The following 2 users liked this post by Discount Tire:
shenny88 (07-21-2023),
wydopnthrtl (04-23-2023)
