Anyone Recognize this Shift K**b?
I had picked up this k__b and mgw shifter from the C6 forum but have not been able to figure out how to secure k__b to the shaft. I have not found any mgw k__bs which look like this one so I'm not certain who makes it.
Before I give up and just purchase another k__b that would fit the C6 shaft, I was wondering if someone might recognize this brand of shift k__b and know how to access allen key that is located inside the shaft.
Based on the indentations on the shaft, the key would appear to serve as a set screw to lock the k__b against the shaft. It appears that the k__b could be made of an upper and lower section but that's just a guess on my part as I cannot unscrew the upper half from the lower half of the k__b to expose the key even after spraying the seam with liquid wrench.
Any thoughts would be appreciated.
Thanks for all the help in advance.
ArmchairArchitect (04-06-2021)
Black 03 Z06 (04-06-2021)
The following 2 users liked this post by jackthelad:
USAZR1 (04-06-2021),
walleyejack (04-06-2021)
Shift k**b.....
Now do I feel embarrassed.... I had noticed most forum members avoid using the actual word in posts that I had seen and just thought that was proper forum protocol.
Well now I am better informed and won't make that mistake in the future!!
Thanks!!
Thanks!!
I thought we were going to find out you were in the UK!
NCM Lifetime Member
Received 3,958 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
^^^^That’s a good one!!!
