02 zo6 part recommendations during tranny pull.
Hey guys, gotta replace the slave cylinder on my 02 zo6. 48k miles, fbo, aftermarket camshaft. I'm looking for recommendations on what to replace and with what since the tranny is getting pulled. I'm not going to track the car at all, I plan to preserve it. I'm looking to increase drive ability not necessarily performance, if those coincide great. Looking for value upgrades not top tier stuff where logical. Also, just things that are a good idea to replace while I've got it pulled Any help would be appreciated. Thanks guys.
Tick slave cylinder with remote bleeder has come in handy so many times
It depends on how far you are going. Are you removing the clutch? If so, Rear main seal, Oil galley bar bell, also check torque tube drive shaft rubber couplers.
Yes plan to pull the clutch. Looking at replacing that and flywheel potentially. I have a great mechanic nearby so I'm trying to get all my ducks in a row and order what I know I want to replace based on your guys thoughts and what he might recommend after seeing any wear once he gets in there.
Also the pilot bearing.
