Tires
Tires
I purchased new tires recently. They are Firestone Firehawk Indy 500 The tire tech put 35 PSI in the tires.
Should I put the 30 PSI in these tires
Thanks for your imput
My wear line is usually perfect at 32-35psi, and that’s on a road course with street tires. 35 is probably fine around town. You can put them at 30-32 if you want. I usually keep 32-33 all year round.
Received 3,112 Likes
St. Jude Donor '21-'22
If they are the stock tire size, on the factory rims, I would go with 30 PSI as this is what's called for. If you've changed rim and tire size, that may change the recommended PSI.
The following 3 users liked this post by MWWarlord:
Pro Mechanic
30 lbs. cold, no if's and's or but's.
Boeuf (03-19-2021)
Received 2,708 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Beast (03-20-2021)
Received 19,391 Likes
'20-'21-'22-'23-'24
30 psi cold is what is recommended. I would not be running 35 psi cold in the tires.
Boeuf (03-21-2021)
