Anyone driving their C5 with the ORIGINAL Goodyear Eagle F1 Run flats?
Received 3,129 Likes
Finalist 2020 C7 of the Year -- Unmodified
Anyone driving their C5 with the ORIGINAL Goodyear Eagle F1 Run flats? Just purchased end of December a 2003 50th Anniversary with 3600 miles on it but tires are original and look Brand New?????/
You would not pass state inspection with those, even if they are perfect. Tires have to be under 7 years old to be deemed road worthy IIRC. You could hoon them to **** in a parking lot somewhere or store them for the sake of being the most thorough collector and put a new set on.
The following 3 users liked this post by LSgoBRRR:
The following 2 users liked this post by Smoken1:
Always Red Dave (02-19-2021),
JDM_Corvette (02-26-2021)
The following 2 users liked this post by RC81:
vetteish (02-19-2021)
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
18 year old tires!!! Good way to test your driving skills when you have a blowout at 65. It is recommended to change tires after 7-8 years at the latest. Don't gamble with your life and those of your loved ones.
The following 3 users liked this post by laurent_zo6:
I bought my 50 A E from a dealer here NC,,,,,,,it had a set of Run flats with DOT 0311. Took them off back in the summer,put Grenerals. I think these are the second set that were installed on the car. They look good and the inside has no cracks or been repaired. The best advice is to offer them to someone as a tire to be mounted on orignal wheels for judging at a show,
JM,02W
JM,02W
2021 C5 of the Year Finalist - Unmodified
You have two beautiful Vettes and an unbelievable garage and you have to ask if it's ok to drive on 18 year old tires. Common sense should be the judge here. Buy another set of wheels and tires to drive on and use the originals as wall art.
The following 4 users liked this post by Adwest52:
JDM_Corvette (02-26-2021),
JimHarris4 (02-20-2021),
leadfoot4 (02-20-2021)
Received 3,200 Likes
St. Jude Donor '20-'21-'22-'23
No, because 18 year old tires are unsafe.
Again.
Again.
The following 5 users liked this post by Stingroo:
Boeuf (02-21-2021),
heggsc5 (02-23-2021),
I drove on my original run flats when I first got my C5. They were noisey and very slippery to drive on. It was a night and day difference with new tires. The old tires were basically hard and had lost their "rubbery" properties.
The following 3 users liked this post by C5MSG2004Vert:
When I purchased my 02 vert years ago it had those tires on it. They were very hard and easy to spin with poor traction. Replaced with Hankook V12 and no its hard to break them loose. Old Goodyear run flats are a hazard
Melt the rears in the parking lot, then throw them in the river, just kidding lol
No way, I'd never go that long without replacing tires unless the car sat in a garage and was NEVER driven. My '03 Z cam with Bridgestones from '14 and I replaced them. They had no damage or signs of wear, but the traction was terrible and I could tell the rubber was drying out.
The following 2 users liked this post by slapshot12:
Boeuf (02-21-2021)
The following 5 users liked this post by Fcar 98:
ApexZ (02-19-2021),
Boeuf (02-21-2021),
Those are very heavy duty tires. Have to be when they're runflats. But at 18 years old......Let's put it this way. An 18 year old girl is old enough to F--- you, and so are 18 year old tires!!!! Beautiful car. Keep it that way with 4 brand new tires-ASAP!!! If I may give you one more bit of advice, personally, I'd never buy run flats again. More money, less traction, stiffer ride. Hope this all helps......
The following 5 users liked this post by grinder11:
MWWarlord (02-23-2021),
vette4fl (02-22-2021)
Ok but I see they still make a Brand New Goodyear Eagle F1 run flat wouldn't I just buy those to get as close to the original as possible. Thanks guys for the advice even though I kinda new the right thing to do already! They just look perfect like a new car with 3600 miles on the odometer!
Put 'em up in storage and get a different set of wheels.There certainly IS a subset of the community (NCRS, I imagine) that values original tires, but I wouldn't drive on them. Remember - it's not just you that's at risk there.
I'll agree and reinforce the safety issues of 18 year old tires! I have had this thought also, with a car of this age and such low miles it has had to be parked somewhere for a long time! Was anything done to protect the tires from flat spots? Did it set on jack stands, tire cradles, or even a piece of carpet under each wheel? If not, I'd bet that the tires aren't perfectly round any more and if you did drive the car, I doubt at a 'city street' kind of speed you might not notice.
But highway speed, you would definitely feel it! And depending on how bad the flat spots are/were your fillings would feel like they were going to rattle out..
I have a 50th AE and would understand not wanting to change the look of your car. You have a very pristine and beautiful example. And as the saying goes ' They're only original once!
I would hazard a guess that the wheels are in excellent shape, no curb rash, dings, dents? But you have a golden opportunity if you did want to change wheels and the look of you car to do so now. You could up size to 18 and 19's to fill out the openings more, maybe get a little more width front and back for more grip. You might even find another set of 50th AE wheels, although I have never seen another set offered for sale, to use as your 'driver' wheels and save this set for shows. With the original set of wheels and tires if you were interested in doing something like a Bloomington Gold status or 'Survivor' label for the car then the originals will go a long ways! Not sure if it has to be 25 years before it could be called a Survivor or not, either way that's not to far away. You could even say that the tires 'Still have original air in them'...lol!
Received 1,872 Likes
LOL, OP made a post thinking it was a badge of honor to still use the original tires, then gets roasted
Stingroo (02-19-2021)
