Cheap C5 Build
#61
Both of my key fobs were working intermittently one better than the other but neither worked as
as they should. It was due to bad contacts. So i soldered light gauge wire to both contacts. Key fobs work as they should.
#62
Bit like you I’ve been reviving my late Uncle’s ‘99. Pewter Auto which lay unused outside for 9 years. Been going through things bit by bit. Afraid to say I await an expensive used EBCM from the states (I’m 90% sure I need it). I’m in the UK so getting parts is less easy here.
I wanted to add to go through all the ground point “splice packs” and clean up the contacts. They’re notorious for causing electrical issues. Well worth doing.
My car seems to be coming along well and I’m hoping to update my thread on it before too long. Mine needs painted too and like you I’ll do lots of prep. Not rushing on the paintwork though.
Keep up the good work!
heres mine
heres mine
The following 4 users liked this post by silver50:
#63
heres mine
heres mine
#64
Thanks. I was going to do a colour change but the Pewter growing on me!
Another good thing to have by you is the Chevrolet workshop manuals for 1999. I’ve found them invaluable at times.
do check these splice packs as routine maintenance. This was my one on the passengers side behind the headlight. My car was sitting in the hot south of Spain so not a cold damp climate but the terminals still went like this.
#65
Funny you mention it, my manuals came in yesterday!
#66
Shifter rattle and loud squeak
So I had this terrible rattling noise, it almost sounded like clutch chatter. It was coming from the shifter/Trans tunnel area. I pull the stock shift **** to investigate and finish off my shift boot install while in there. I went out for some adhesive with no shift **** and the rattle was gone.
so I finished my shift boot and put on a momo shift **** I had and all is well.
Next was the squeak that a chased down to the rollers for the top locking mechanism
#67
Awesome build. Congrats great work!
knockingdiesel (02-15-2021)
#68
Windows are tinted, most of the drivetrain parts are here
The following 2 users liked this post by knockingdiesel:
HotRod Junkie (03-03-2021),
Tusc (02-27-2021)
#69
Been a while since I posted, I adjusted the top, hood and trunk and most of the rattles and squeaks are gone. I have been busy working on the TA now.
Tusc (04-24-2021)
#70
Received 3,201 Likes
St. Jude Donor '20-'21-'22-'23
Ooo love that 4th gen. Cool color.
knockingdiesel (04-24-2021)
#71
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Love that Medium Blue on the T/A. Too bad they never did a WS6 in that color.
#72
I bought the 4th gen for $1400 and have more money in it than I do the corvette, although it was much worse.
#73
Update
Installed Callaway Honker, I cleaned the TB before final install.
#74
$3,400 Why can't I find that kind of deal? She looks rough but if she runs well you got the deal of a lifetime.
As far as the EBCM, I would not invest the $ to replace it. I know of no way to tune out the lights on the cluster. Hopefully your friend can figure out how to do that and I hope you will post a "how to" so others can do it. Personally, I own two 99's with no problems but recently had to repair my 02's EBCM. The 99's cannot be repaired but the 02's can be. Best wishes
knockingdiesel (06-27-2021)
#75
