Exhaust upgrade questions
Hi All, new member to the forum. Also new to Corvettes. bought my 99 vert a year ago. Its bone stock
My question is about the exhaust. I love the sound of the exhaust, but want it louder.
Do i need to get a cat back system such as Borla (appx $1400 for part alone). or is there a cheaper option
Received 3,112 Likes
St. Jude Donor '21-'22
First off, Welcome to the forum!
There are several exhaust options. A cat back system will likely get you what you want. Borla and Corsa both offer good options that won't drone like a lot of the cheaper systems will. Another option that might work well for you would be the bypass mod. This involves adding a pipe that goes from just before your muffler to just after the muffler. This does not bypass the muffler completely. It has no drone at all, and is not obnoxiously loud. However, it will make the exhaust louder. Most exhaust shops can do this for you for a couple hundred bucks. Here's a picture of what I'm talking about.
http://images.app.goo.gl/jUDUdxjcfUskcAUz8
Note: the picture is of the Ti exhaust from a Z06, but it will work exactly the same on the steel exhaust in you vert.
wmupaprmkr (02-03-2021)
NCM Lifetime Member
Received 3,935 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
All you need is an axle back system. There are flanges just before the rear axles, and the new system will connect from that point back.
If you want the Borla ATAK system, go to Complete Street Performance's website late at night, like 9P. The advertised price is lower at night (around $1200) for whatever reason, plus if you use the coupon code oct2020, you get an additional 5% off, which puts it at about $1147, IIRC.That is the best deal I have found it for on the internet.
https://www.cspracing.com/borla-atak...design/140428/
I just recently purchased this system and I am very pleased with it after trying several different ones over the past few years. It has a good tone, good volume, and zero drone.
thank you Warlord and lewislg
i think the axle back system is what i meant, even though i said cat back. are they the same?
thanks for the pic Warlord of the bypass. Like the say, a picture is worth a thousand words. I like the price of this option.
I have the same car as you with a billy boat rt 66..its a bit too tame for me so after a lot of research I'm thinking of the Corsa Extremes. No drone. My BB's have a bit of drone at 65mph..some of the other systems have a lot which becomes annoying.
Glad I could help. The bypass mod is much cheaper, and I suspect you'll be happy with the result.
They shouldn't have to remove the whole exhaust, but they would almost certainly have to remove the axel back portion of it. Any good exhaust shop will have a lift, so removing the needed section is only as hard as removing 4 bolts and sliding the muffler brackets out of their clips. The removal and re-installation will take 20 minutes or less total. Doing the actual mod itself will take a bit longer. However, this is definitely something the shop should be able to do while you wait.
In my 2000 vert, I went with Borla 140017 which has two large 4.5" tips. Current pricing seems to be about $700. Sound is raspy and loud. Adding an additional X pipe will help to reduce popping and gurgling but I liked it without.
I installed the system myself on jack stands, no drama. I left everything loose, aligned all the parts till it looked straight and then tightened all the clamps.
I went with OBX SS Headers 1/3 the price of the mainstream ones, Basani crossover and GHL mufflers, its loud but no drone and at cruise its quieter, had in on now for 7 years. I had Billy Boat and my ears used to ring for an hour after getting out droned a bit, manual car.
Received 19,373 Likes
'20-'21-'22-'23-'24
Depending on just how loud you want to go, you could do a B&B Route 66 system - I had one of those on my '00 C5 and it was a little louder than stock and looked great with the quad oval exhaust tips.
Best bet is to wait a while and try and go to some car shows or cruise-ins and listen to the exhaust that may be on the C5s that are there. Talk to the owners - I would bet many would be very willing to fire up their car so you can hear the exhaust.
NCM Lifetime Member
You have to put your address in for the free shipping to show up. I ordered a Borla system for my 2020 Silverado and it showed up in like 2 days. Great service.
lewislgZ06 (10-30-2020)
NCM Lifetime Member
