Best Battery
Best Battery
I am struggling to find a decent battery with over 700 CCA with a warranty more than 3 years for my 2004 C5. I had a sealed Die Hard Platinum that lasted 8 years and 3 months and cannot find a decent replacement. Any recommendations?
Here is a post I made. You might consider the same battery except go with a AGM version.
https://www.corvetteforum.com/forums...d-big-3-a.html
killain (09-25-2020)
Odyssey Extreme 34/78 850 CCA. For many years, Sears sold this battery as the Sears Platinum, but at a lower price and a great warranty. I bought one in probably 2007-8, 12-13 years ago, and it just keeps on going.... Definitely expensive, but short of going Li Ion, the best there is. As and when it dies, I'll be getting another.
Die Hard Platinum equivalent
Die Hard Platinum equivalent 850 cca........... https://www.odysseybattery.com/produ...-34-78-pc1500/
Received 2,708 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
I don't care what brand you get, just be sure it's an AGM type. Yes they cost more but they won't possibly leak acid on your car. My personal favorite is the Optima Yellow Top.
I understand you AGM approach. In my case after 22 years going on 23 with the vette, i never had a problem with a regular battery leaking, They all lasted 5 years and i traded them out if they needed it or not. Except for the last battery i had a optima red top. Stone dead shortly after 3 years. Just put in OEM stock battery ACDelco top of the line, one more thing also add an acid Battery Mat $13 cheep insurance.
'23-'24
Thanks for your thought and I understand that the vast majority of lead acid batteries do not leak.
Over the past 17 years on this forum, I've learned not to skimp out on $ buying a lead acid battery on a C5. There are just too many horror stories of the leaking acid on the C5's electronics that are below the battery. If you don't believe me, go to "advance search" then C5 forums and search for "battery leak". Enough stories there that I'll keep buying AGM batteries. Plus, I get great longevity out of the Yellow Tops. I've had not so good of luck with the Red Tops but I currently own two of them. I own four Yellow Tops. I also own a ton of battery tenders
Here is a picture of my latest creation in wiring in a Red Top (Eagle Talon TsiAWD) Yes, that battery is six and a half years old.
I had an Optima Red for 17 years, finally died. Was an amazing example of any AGM battery. Choices are basically AGM or not.
Odyssey batteries are best-in-business to give scale.
killain (10-03-2020)
went to a seminar at Carlisle two years ago with Paul Korner, Corvette Mechanic. He explained that C5's are very finicky in the voltage category. He recommended AC Delco 78PSHR due to it having more
reserved voltage than any other battery at the time. He said upon startup that so many different things are done with voltage that if there isn't enough store voltage you get "pull key, 10 seconds" among having
other issues. I bought one and don't have any issues unless I let the car sit for long periods of time (couple of weeks) without the trickle charger.
Even parts guy at the dealer hadn't heard of this battery. The one his computer recommended for my car had far less stored voltage.
The original spec for the C5 was an RC of 90, we found over the years that (due to parasitic drain) and RC of 120 is better.
Any battery with an decent RC will serve you well (like the one you had in for eight years....and the one that I used).
Pro Mechanic
I just purchased a DieHard Platinum AGM Battery, Group Size 78, 740 CCA from Advanced Auto Parts. It has a 3 yr warranty. Normal price was $200, but they had an online sale for 20% off a few weeks ago, so I got it for $160.
Received 19,363 Likes
'20-'21-'22-'23-'24
Get an AGM battery for sure, and Odyssey batteries are very good.
knewblewkorvette (09-26-2020)
'23-'24
Was doing some garage clear out yesterday and came across the receipt/warranty for my Sears Platinum - installation date 11/08/2008, price $189.99. Still going strong. Best battery? Yep. BUT today's Platinum is not made by the same manufacturer, so don't expect 12 years. To get that battery you have to buy an Odyssey - about $300 or so, IIRC.
FYI - your Diehard IS an Odyssey battery. It was just relabeled for Sears. That joint venture ended 6-7 years ago though. Odyssey batteries are THE best AGM lead acid car battery on the market.
The *best batter would be lithium, drop some weight. With some seats as the biggest 2 easy weight mods
Last I would run some shorty headers to stay emissions legal and again drop some of that cast iron weight, into nice stainless CARB certified. ANOTHER 15-20 lbs!
