Prices for New Transmission vs Rebuilt?
So, I think the transmission on my '04 auto (119k miles) is slipping. Once it hits 3rd gear it starts to rev extremely high and makes some jerking movements. And once it hits 65-70 the RPMs will go into the red and jerk the entire vehicle before I release the gas to downshift. Also, pressing the gas results in very high revving before barely any actual movement takes place. I thought it could low transmission fluid so I had that done earlier today along with some other fluid changes and it didn't change anything, although the filter might still be the issue. Taking it to the dealer Monday to see what they say, but I'd like to weigh their prices vs getting one myself and having a trusted transmission/tuner shop install it. Any tips or ideas?
I'll try posting a video showcasing the issue, but it's kinda hard to make out over video.
Received 3,112 Likes
St. Jude Donor '21-'22
So My (auto) transmission blew when I added my A&A supercharger. I was shocked to discover that a stage V transmission from RPM wasn't much more expensive than a new OEM transmission. Just thought I'd throw that out as a third option. That would make your transmission virtually bulletproof for anything that you may decide to do.
CorvetteBrent (07-09-2020)
Yes! RPM backs all of their products. Just a heads up, in my case we sent them the stock transmission out of my car, and they reused the housing. This doesn't have any effect on performance or reliability, it just lowers the cost.
The following 4 users liked this post by MWWarlord:
CorvetteBrent (07-09-2020),
ItsAVetteThing (07-08-2020),
leadfoot4 (07-09-2020),
Moto One (07-09-2020)
So they sent you the unit and you just sent or old one back? Or you had to send them your transmission first?
So, my transmission shredded third gear while it was on the dyno. My speed shop actually handled the transaction for me. However, as I understand it, they sent them my transmission, and they built the new transmission in my existing stock housing. This was a few years ago, so things could have changed. It should also be noted that at the time RPM had a one month backlog. However, the transmission is now absolutely bulletproof. I do know that RPM has GREAT customer service. If you contact them, I'm certain that they could work something out for you.
RPM away wants a core. keeps the price down. They will send you a new (built Trans), you return your old one.
Great trans by the way. Great people to work with at RPM.
Mark.
Mark.
I went with a dealer rebuilding my C4 transmission - afterwards and realized it would have been smarter to have gone with a rebuilt because it would have a better warranty - as it turned out I had to take it back to the dealership for additional work that ended up costing me more money.
From experience, replace the old factory torque converter with a good aftermarket one because if it fails it will send debris into the transmission requiring a rebuild again.
Received 1,256 Likes
2016 C5 of Year Finalist
Do some shopping ..there are plenty of reputable after market
tranny shops. Most are far better than OEM. Buy a aftermarket torque
convertor. When I bought my tranny ,I used the same crate to send back
my old tranny. Very easy transaction.
Good luck
Good luck
