View Poll Results: Should our Bi-X ACA headlights be offered with a Bi-LED projector?
Voters: 46. You may not vote on this poll
Gauging Interest: Bi-xenon to Bi-LED ACA headlights?
Supporting Vendor
Our Bi-xenon ACA headlights have been the top-shelf headlight system for the C5 since their introduction in early 2012, however LED projector technology has progressed to the point where it has now surpassed HID in the following respects:
- Longer "bulb" life
- Instant startup
- Lower current draw
- Consistent focal point
- Overall brightness and further "throw" (The Bi-LED projectors we're considering produce about 20% more effective output than the HID projector system we're currently using. This includes the central hot-spot, width and high beam performance)
The biggest single drawback (as with any new technology) is comparative cost. Our best guess is that going to LED projectors would increase the cost of our kits by $200 (total cost would be $850 retail). We would also need to re-engineer the mounting system to accommodate the new projectors to any decision to proceed would take about a month or so to implement.
For those of you not familiar, these are the ACA headlights:
https://sharplightinnovations.com/sh...aca-headlights
- Instant startup
CorvetteBrent (02-11-2020)
Supporting Vendor
The Bi-xenon DIY Kit is currently $250. (this includes projector assemblies, all required hardware, Hi-4 harness and high-output LED high beam bulbs)
https://sharplightinnovations.com/sh...t-modification
If we move forward with the Bi-LED projector, I will offer a DIY kit as well, however the price will be more expensive than the HID projector version.
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
Really appreciate our Bi-Xenon for night driving, but a Bi-LED upgrade would be a real consideration.
I bought your bi-xenon kit because you said the bi-LED kit would be far away, due to sealing issues. If you've resolved those, I may well spring for the LED upgrade.
That said, $650 isn't super cheap, and $850-900 is also not super cheap. I think you would do best offering a lower-cost option ($650) rather than only selling the higher-cost option.
Out of curiosity, what causes the cost to increase so much? I would have hoped that getting rid of HID ballasts reduces cost.
Supporting Vendor
LED technology is more expensive for a couple of reasons:
1) It's newer than HID and anything "new" is automatically more expensive. HID bulbs are pretty much standardized in production with minor differences in bulb base, and ballasts. Companies have had an opportunity to recover startup costs on the machines and tools that create those parts. LED projectors on the other hand are so new in the aftermarket world that there is no "standard" set yet. Machines and tools are new and companies are fighting for market share by trying to balance cost with quality. There are cheaper quality Bi-LED projectors, but their optical performance is comparable to halogen projectors.
2) LED projectors require more tooling than HID projectors. Not only do LED projectors require LED drivers to power the LEDs (which are comparable to HID ballasts), but often they require cooling fans, custom PCBs and high quality precision reflector optics to compete with HID projectors.
George, I installed your non-bi-xenon HID's on my 98 back in October 2013, and passed on the bi-xenon upgrade you offered a few years later.
Will your upgrade kit be compatible with my set up?
Supporting Vendor
Received 1,261 Likes
what's the difference between an hid and led projector?... would swapping bulbs yield any noticeable differences (good or bad) or are the optics actually different?
I like the idea of Bi-LED option for the package. I also have been using your Bi-xenon's for two years and the only improvement to suggest is moding the high beam to a stronger "pencil" beam for additional down the road illumination. Would two dedicated hi and lo projectors be cost effective vs the bi-beams?
Tom
Tom
Received 2,709 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
I'll be honest with you as I've been eyeing these lights of yours for along time. Cost...cost is what's keeping me from pulling the trigger. $650 is a lot to me to spend on headlights, especially since I don't do a lot of night driving. So, personally, I definitely would not want to spend an additional $200 for a 20% brighter light.
P.S. I thank you for providing an upgraded headlight for our C5s
Kiddbats (02-12-2020)
i still have my original 2004 lights so I would be interested, particularly if there is substantial weight savings over the stock units. That helps justify the price for me as a mostly track day car.
Supporting Vendor
Here's a comparison we did between the MH1 HID projector and the Bi-LED projector we now use in our Fixed Headlight system.
HID projector
LED projector
Simply swapping in an LED bulb into a Projector doesn't work because an LED bulb does not have a central "point" of light like an HID bulb. As a result, the pattern from the projector is not properly focused and substantial throw is lost. LED bulbs are acceptable in high beam reflectors where a flood-light pattern may be preferred to a spot-beam, but in the low beam (particularly a projector) the bulb must be designed for the housing.
Tom
Tom
If Pure performance is the goal, our Stealth Light Cannon V3 (fixed headlights) use a Bi-LED main projector and a Dedicated narrow-beam LED high projector that provide a clear visibility of 1000 ft. (We're testing this combination as a replacement system for C6 headlights)
tcfamy (02-12-2020)
Supporting Vendor
The Bi-xenon (or Bi-LED) ACA headlights are heavier than stock, but the Stealth Light Cannon V3 Fixed headlight system is just 12 Pounds. (A bit more expensive, but about half the weight of the factory system and all in the nose)
Supporting Vendor
I don't recommend our LED bulbs for use with Non-Bi-xenon systems. They do not have the same output as a halogen bulb and we couldn't get any brighter bulbs due to clearance issues with the lifting arm.
