Tubing for Modified Ranger Method
Want to try the modified Ranger Method on my clutch fluid. Tried to find the 1/8” OD tubing and having trouble finding it. Found some 0.140 OD at a Hobby shop. Does anyone know the Max OD that can be used or any info on a syringe/ tubing combo that can be purchased as a single unit that will work??
thanks
thanks
Bob,
Just ordered the syringe yesterday and should be here Friday?? from Amazon. Also ordered some Autometer 1/8" gauge line. I'll post results/picture soon.
Happy 2020 -- Tom
Happy 2020 -- Tom
USAZR1 (01-02-2020)
By modified, are you talking about getting tubing to suck even more fluid out of the line itself? Are you sure that won't risk introducing air into the line? I don't see why the normal Ranger method wouldn't accomplish the job without the risk...?
STALION (01-03-2020)
Received 3,043 Likes
St. Jude Donor '05
How bout some mild steel brake line type tubing, take the rubber stuff out of the equation. Bet the clutches work more precise may just do this myself.
When old brake lines go bad thebrake pedal sinks (lines swell)so....all this flushing I think is nonsense No car requires that all the time its something else.
2020 C5 of the Year Winner- Unmodified
Just did the Clutch fluid. Found the 1/8th tubing at O'Reiley. Did it just like the mod ranger thread described. All it is , is replacing the dirty fluid. Mine wasn't so bad since the clutch was replaced when I bought the car a year and a half ago. I don't daily drive it, so not many miles. But it was a little dirty, and in some of the Youtube videos it was black. I'll just keep an eye on it once in a while. It was the easiest thing I've done to the car so far.
