napa replacement clutch?
has anyone used a napa clutch assy? I have an 03 z06 with 85k and looking for a clutch. napa has a kit complete with flywheel, pressure plate and friction disc. price is around 400.00
If you can find out who makes the napa clutches you may have a good kit there as long as it isn't chinese crap. A Luk clutch kit is where most people land here on a street driven car, as they are the OEM supplier. The flywheel is heavier on the replacement kits, so do some searches for threads on it. Some people say you can't tell and others say "it's smoother". The important part is to put in quality parts, as it's either very time consuming and hard work or very expensive if you pay a shop to do this. Read as many threads as you can - about balancing, parts choice, etc.
https://www.summitracing.com/parts/l...5/applications
This is a great price on an aluminum flywheel setup, with the same pressure plate and disc as above.
https://sdparts.com/i-23179965-sdpc-...-flywheel.html
For as much work/money (if you are paying labor) I would spend the money and get the LS7 clutch or a good aftermarket clutch. It is an absolute pain in the *** to change a clutch in a C5.
KT
KT
FYRARMS (11-15-2019)
How about full LUK LS7 replacement clutch kit with flywheel for $239?
It's $227 on RockAuto right now, and shipping is about $10 so similar price to Amazon.
The following 3 users liked this post by MetalMan2:
A lot of people use the ls7 because it can handle higher horsepower applixarions. If your c5 is stock or just some bolt ons, the oem clutch is more than enough. If you have boost etc than ls7 or aftermarket is a better route. I do know a few people that have installed the ls7 on their bolt on c5 and weren’t happy. Heavier clutch etc. It’s always a dangerous road to go down of using products that weren’t intended for your car. Unless you have a highly modified car or you have a specific reason for changing, there is really no justification for using anything but a stock clutch. My car has 125k and I’m on the original clutch. Not sure what an upgrade to an ls7 clutch would get me. I’m pretty happy thus far.
You merely were digging into what I was running but anyways it’s cool don’t make me part of your ruff day!
Slow Vette complex apparently!
