4eyec5 low rise headlights... about to install
#161
I think the only possibilities come in 70 and 80mm, but maybe an 80mm would work I think? Something like these (not that I would use something this cheap, only for reference) I would guess, and held in place with some 3M automotive molding tape cut to an appropriate width.
Let me revise that - the 2.5" would be 70mm and hopefully not too big. The 80mm would work for the 3" fxr.
#162
1). Better is subjective, but a bi-xenon functionality when combined with a 4-hi harness would be insanely bright with the hi-beams on.
2) Use either an LED or Xenon bulb in the hella, toss the halogen in the garbage.
3). Absolutely do this. I now prefer LED over xenon, but a 4300k xenon can have that perfect OEM color to them.
Anyone have an email for 4eyec5?
#163
Thanks, I won't need anything crazy since anything will be better than the stock setup. The common Hella setup with a cheap HID in low beams and halogen high beams would be fine. I may, if I'm bored, look into making my own 4-high kit but if I'm happy with it initially I'll leave it alone.
#164
Received 1,261 Likes
I swear I saw a place that had a harness that plugged in between the factory headlight harness to make all 4 lights come on instead of using fuses in the fuse box and cluttering up the battery area, I could be mistaken but I'm going to see if I can find it
#165
Order confirmed by 4eyec5...game on!
And count me out on the FRX due to it being an open projector. Not spending that kind of money on something that needs a less than ideal solution to become sealed...
Hellas plus a cheaper HID kit for lows with halogen for highs and 4-hi mod should be PLENTY functional.
2k2wranglerx (01-28-2020)
#167
CF Superior Member
St. Jude Donor '07, '11-'12-'13-'14-'15-'16-'17-'18-'19-'20,'21-'22-'23-'24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
Would you be willing to post up a diagram for this harness? I would like to make my own harness also.
#168
The following 6 users liked this post by CinciZ06:
heggsc5 (02-03-2020),
helphos (01-29-2020),
niterydr (01-30-2020),
NSFW (01-30-2020),
smitty2919 (01-29-2020),
and 1 others liked this post.
#169
It has been so long since I have dealt with adding an hid kit to a car. I plan on just using a morimoto 9006 kit with their harness for the low beam, and I will leave the high beam a halogen.
I would be interested in the All 4 harness diagram as well if you could whip something up.
#172
Thanks!
#174
So which LED bulbs are everyone running? Any reviews of the suggested 9600LM Hikari led bulbs? Anyone upgrade to the 12000lm bulbs? Any fitment issues?
#175
I'm running their recommended bulbs and i think they look great. Good color (not too blue) and they seem to jive well with the cut off on the housings.
#176
Who all has used HIDs in the low beam hella? Is the light pattern decent being a halogen projector?
And what adapter is everyone using from the 9006 factory male plug to the 9005 bulb socket?
If the HIDs look decent in the housing then I am going to use the morimoto HID kit..
https://www.theretrofitsource.com/90...ect_restrict=1
#177
here's a screen grab from my install video (i hadn't fixed the shake issue at the time in the vid). it gives you a good idea of color and beam pattern. This was when i was aiming them.
This is what an LED headlight beam pattern SHOULD look like. those round hot spot with tons of spill low rise light bar headlights have a terrible pattern compared to these.
#178
mykream (01-30-2020)
#180
So what adapter is everyone using for the 9006 factory low beam bulb to the 9005 bulb of the low beam?
I don't understand 4eye's post where it says:
Qty.(1) set (only needed if not upgrading to LEDs and you are keeping 9005 bulbs that come with hella lights, but not recommended)
If we are switching to a 9005 low beam, you would need an adapter harness
