Change oil while engine is cool?
I hate working on hot cars and usually change oil while the engines are cool.
It flows out pretty good, and I let it drain usually about 10 minutes after raising the back of the car to get the last bit out.
Does the engine being up to full temperature really help?
Received 3,893 Likes
2015 C5 of the Year Winner
I use to work in a service station and was always working on hot engines, so I didn't know any other way. I've always had them at least a little warmed up since I've been away from that line of work for quite a while now even here in AZ. Just my old school mind taking control I guess.
Synthetic 5W30 flows pretty good when cold. I change mine cold or hot. It really doesn't matter. I remember in the olden days when some of that cold oil ran like molasses. No more.
If you change it cold after the car has sat for awhile you get more of the old oil out. Just make sure the back is a little higher than the front, since the plug is on the front of the pan.....and make to fill filter with new oil before you spin it on.
Received 19,439 Likes
'20-'21-'22-'23-'24
I change mine when the engine is cold. Really don't want to chance touching some hot components when doing the oil change.
well for regularly maintained engines with detergent oil in moderate temps it doesnt really matter.
The car being level to a little higher in the rear is more important than oil temperature as the front drain, low sump and pan baffles need to have the car near level to a little higher in the rear when changing oil. Otherwise all you'll be doing with the oil being hot is risk burn.
redzg (07-18-2018)
I do it cold in the spring (on ramps when I park it for winter). After it drains I jack up the back a bit from level, let it drain further. Done.
