Fuel Line Retainer Clip...help
St. Jude Donor '13, '15
I removed by aftermarket fuel rails and reinstalled the factory lines. I apparently lost one of the metal fuel line retainer clips at some point. It looks like this:
All I can seem to find online this morning is a Dorman plastic clip like this:
Will this work just as good, or should I keep looking for the factory style? Is it safe to drive the car without this retainer clip, certainly don't want to have the line come loose and cause an engine fire.
Received 19,390 Likes
'20-'21-'22-'23-'24
Or try contacting one of the used parts vendors here on the forum and see if they have one in stock.
Can someone take a quick peak and see if you have a clip on both ends of your lines, or just one. I've been doing some searches and even revisited Mark's (ToqueZ06) site and it appears perhaps the clip is only on the fuel rail side. Nothing at the firewall connection, which is how I have it now.
1/4 mile/AutoX
still need a release tool to remove it, so how ness. is it ??????
1/4 mile/AutoX
