Friday evening = new MGW shifter
Just finished installing my new flatstick MGW. The install was very straight forward. I wasn't as fast as the guy in the online MGW videos on the website, but no issues. It's raining and I refuse to put the top up this time of year (okay, the car's clean) but I started it and shifted through the gears smooth. It even slid into reverse nicely. I'm optimistic for the test drive. Cheers!
Congrats, looks nice. I'm sure you will enjoy it! I have been on the fence between the MGW and the B&M and I believe I am going with MGW. Did you buy yours directly from MGW?
Banned Scam/Spammer
Received 1,319 Likes
I drove a C6ZR1 with that shifter and it was literally perfect. Worth the $400.
I already had an aftermarket shifter so I had my lower box rebuilt by TMODS (vendor here) for $125 and it feels the same. If I didn’t already have my setup I’d make the MGW my 1st mod before anything else. It’s that good.
Banned Scam/Spammer
They give 5% off just by asking. I was buying them for customers and inquired about being a volume vendor; they said they don’t do that but I could get 5% off.
Simply ask for it and you’ll get it.
I've heard nothing but good thinks about the TMODS rebuild. Wish I would have heard before I bought the C6 Z06 I just replaced. The C6 was definitely a huge improvement over the C5 shifter (with 65,000 miles) but not exceptional.
Banned Scam/Spammer
The c6 shifter **** has some flex in it. The cue ball on the mgw has zero flex and with the right tolerances it gives a smooth mechanical feel that is hard to reproduce. If you didn’t get the flat stick version and reused the c6 **** the feedback/feeling would drop from a 10 out of 10 down to an 8 out of 10.
The cats meow meow is trading the lightweight plastic **** for a heavyweight stainless (not aluminum) **** and you will never go back to anything else. 11 out of 10.
https://www.twistedshifterz.com/prod...CABEgJsr_D_BwE
Mickeyrx70 (06-22-2018)
Received 19,701 Likes
'20-'21-'22-'23-'24
Congrats - nothing like a smooth shifter in a car.
Supporting Lifetime Member
Do you have a pic of it in your car? I’m getting ready to get an MGW and have been looking for something a little different. Have had their shifters before and one of the best mods you can make, but the weight makes it even better?
Thanks for the info on the discount I will probably be ordering mine soon. Not trying to hijack the thread but has anyone tried using a C6 style shift **** that is threaded for a C5 shifter on their mgw? I do like that race **** from mgw but I also like my current shift **** and will probably try to use it as long as it feels good with the mgw.
I too, have been thinking about a new shifter. Can't decide between a MGW or a C6!
Received 2,725 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
I've had/have both. I originally had a B&M shifter in my 98, hated it. Replaced it with a C6 Z06 shifter and it was definitely better. In my 99 I have a B&M shifter and love it. I have a MGW shifter in my 02 and love it too. I recently did the washer mod but haven't had much time to drive the 02 since I'm in the middle of a move. If I was in your shoes, I'd look for a C6 shifter because than can be had for allot less than the MGW and the C6 **** is nice to have.
Banned Scam/Spammer
jon68l79 (06-23-2018)
Ok, I got my test drive in and it shifts great. Very positive feel in each gear and from gear to gear, and a nice throw distance. There's also noticeable more noise coming through the console too. Is that common? I got a nice tight fit between the boots. I imagine the dynomat (and heat shield) were included with the kit to address this? .
Banned Scam/Spammer
Yep. Will have more noise, a bit more vibration, but the vibration level allows you to feel a little more like you’re driving a machine instead of a marshmallow.
Time for a C-5 (06-24-2018)
