Sooo my breathless performance short shifter just snapped in half.
Been running this shifter for MAYBE 6 months? was just casually driving home from work, sitting at red light, go to put it in first and its completely loose. Open up the console and sure enough... snapped clean off!
Never raced with this shifter, never banged gears, nothing. As much as I absolutely hate it, guess im going back to the stock shifter
Any ideas why this happened? $230 down the drain gotta love it!
ArmchairArchitect (05-15-2018)
Received 19,451 Likes
'20-'21-'22-'23-'24
That doesn’t make for a good driving day. Perhaps you just got a lemon. Is it under any kind of warranty? If so and you want to give them a try again, contact Breathless and see about a replacement. If you want to try something different, I too would look at MGW.
jjc508520 (05-14-2018)
2022 Corvette of the Year Finalist -- Modified
2021 C5 of the Year Winner - Modified
My guess is that the shaft is heat treated and the HRc (rockwell hardness) was too much. Hence, the clean straightline crack. I would call the MFG. and have them explain the breakage issue to you. If I were them I would replace your shifter for free and want the damaged one back so they can examine it. They probably have a bad batch of them out there. That should've never happened.
Attachment 48283402
I was looking at picking up one of these used a couple of months ago. I read some other instances where this same exact thing happened. Obviously i passed on the deal...seems like its a real issue.
Received 2,709 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
That should be covered by the manufacturer.
1/4 mile/AutoX
If it were me, I would contact them again and make sure that they know you will be getting the MGW and that you posted this in the Corvette Forum so that everyone will know how good their customer service is.
To OP; I bought a BP as my first shifter about 15 years ago, and it was a real POS.
DDaaryl (05-14-2018)
Just pin it and weld... I'v done this when making my own short shifter.
Mark.
Mark.
Pro Mechanic
I've had a Hurst in my C-5, for 16 years, with no problems.....
Received 1,105 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I hope you told them to “stuff” their 20%.
