Wheels that clear C6 Z06 brakes?
Kubs (12-14-2021)
#42
Received 1,769 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
@Kubs I think you just convinced me to replace my CCW Classics with these in 19x11! What sizes are you running on the 18x11s?
#43
I have used both 285/30R18 and 315/30R18. I like the 285 better since the 315 really needs to be on a wider wheel. The 315 is a little pinched and results in some sluggish turn in. The 285 is a bit more responsive. A 285 or 295 tire would be perfect on an 11" wide wheel. I think in 19" 305 is a popular width that would also work well.
#45
I have a base C5 that I am putting OE C6Z brakes on and need a wheel to clear them. I bought a set of TSW Nurgburgring wheels (18x9 front / 19x10.5 rear) but the company I bought them from said they are on back order for at least 4-5 months but could be longer so I cancelled that order. Then I was going to go with Forgestar F14 but when I contacted them they said the 18" would not clear them even though I've seen other members do it so not sure what that was about. Also they said they are out of stock on the 18" and not sure when those will get back in so now I continue looking for wheels to clear. After reading this I think I'm sold on the Apex EC-7 wheels. Looking to do the 18x10 Front / 19x11 Rears but per Apex website it says it needs 15mm spacers in the rear with stud extenders. Anyone have any experience with this setup? Are they really needed? I've seen other members run other brands of 19 without spacers. Thanks for the advice in advance.
#46
Cruising
This is the fitment I used for my C5 with C6 Z06 brakes using Forgestar F14's. 18 x 9.5 +50, 19 x 11 +55. You will need an 1/8" spacer for the front wheels but there is no wheel poke / flush with body...
#47
