Trading One C5 Vert for Another - What's the Difference?
I have a stock red 2001 convertible (automatic) that has given me no problems in the four years I have had it. I've been thinking recently that I'd like to have a triple black C5 convertible with manual shift. I found a 2000 this week that is pretty much stock except it has an after-market Borla exhaust. To me that's a plus.
I'm thinking of trading my car for this one. The asking price of the 2000 is scareing me a little. Price is $11,995. Isn't that low? It has 108,000 miles and paint looks very nice on the outside, seats a little worn on the inside. Top in good condition. Wheels look practically new. Better than mine even.
What are the differences in the 2000 and the 2001? Should I got for it? I'm wanting it pretty bad.
EBCM would be the biggest difference and might be why the other is so low. But there was a black vert here local for $9k a month ago. I only drove by it, so no idea what the year or miles were on it.
Going backwards to a 2000 is a much bigger step than simply one year difference. The 97-2000 Vettes have major differences in the electronics from those that are 2001-2004. You could get lucky and have no problems with a 2000, however, if you buy one and find the EBCM goes out, or the TPMS need replacing (and various other parts) it can get VERY costly quickly.
phoneman91 (01-06-2017)
One thing you should note: It is easier to secure an automatic equipped convertible than it is a manual convertible when the Corvette is parked in a public environment.
If the top is down and you want to run into a store--even for a short time--with a manual equipped convertible it is possible for anyone to place the manual transmission out of gear and remove the emergency brake and have the Corvette roll. An automatic equipped convertible is more secure--because the transmission is locked in park and the lever can't be moved when the key is removed.
Received 19,407 Likes
'20-'21-'22-'23-'24
Here's a listing of differences in the C5 through the years.
All of this information is variously collected from the Corvette Forum message board, so do not take it as absolute gospel. However, it should be somewhat close.
1997
• Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
• All Z51 cars include: Power Steering Cooler
• 97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
• Convertible becomes available
• Active Handling becomes available late in year
1999
• 26# injectors substituted for 28#
• Fuel pump revised to reduce noise
• FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
• HUD introduced.
• Only one line in driver's side fuel rail cover (no fuel return line)
• Power telescoping wheel becomes an option
• Steering hardware changed to combat wandering
• Door sill trim plates added
2000
• Millennium Yellow available
• "Thin Spoke" versus "wagon wheel" design wheels become standard.
• Pup cats added to all models for LEV emissions requirements (5hp loss relative to 97-99)
• Steel swaybar endlinks instead of plastic on Z51 equipped cars
• Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
• No keyhole on passenger side door handle
• Passenger airbag 'off' switch added to console (light by TC/AH button) – mid-model year change.
2001
• Return to 28# injectors for all models.
• Second Generation Active Handling
• Nassau Blue discontinued
• Alternator 'clutch' pulley added on A4 cars
• New soundproofing + foam in all cars
• Smaller key fob
• Electrochromic dimming rearview and driver's mirrors
• Lighter AGM battery
• Thickness + Material in Convertible change
• Chrome exhaust tips for coupe + convertible
• 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
• LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
• All Corvettes now have the LS6 intake manifold
• All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
• LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
• Hardtop/FRC discontinued
• Stronger synchros in all transmissions
• Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
• Metal valve stem caps (late year)
• Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm.
• Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
• Introduction of the Z06, which has as differences:
• Hardtop body style
• Rear brake ducting
• Screened inlets on front fascia, without foglights
• F1 Supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
• New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
• M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear differential
• Titanium exhaust system
• Lightweight windshield
• New, stronger clutch with redesigned master + slave cylinder
• Stronger rear differential (shotpeened ring gear)
• Red brake calipers (otherwise identical)
• Transmission overtemp warning light on DIC
• 6500 redline gauges with special checkering + Z06 font
• Redesigned PCV system to help combat oil burning
• Red LS6 Fuel Rail Covers (FRC's)
• FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
• Z06 Changes:
• Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
• Less restrictive intake airbox lid
• Descreened MAF
• Removal of pup-cats (total with changes = 405hp)
• Z06 shocks revised with less rebound for better launching
• Z06 brake pads revised for better stopping (generate more dust)
• Lighter, sodium filled valves w/ stronger valve springs
• Higher tension rings installed to prevent oil burning problems
• Slight piston redesign *
• Clutch strength upgraded.
• HUD available on Z06 (not avail '01 model year)
• Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
• Electron Blue color offered
• Steel endlinks changed to aluminum
2003
• Late model-year new fuel system design from C6's
2004
• Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
1997
1998
1999
• HUD introduced.
2000
2001
• Smaller key fob
2002
• Z06 Changes:
• Descreened MAF
2003
2004
