** Oil pressure @ 129 P.S.I. - YIKES! **
Hey guys - '98 manual 'vert - I got in car other day and oil pressure gage was pegged all way around to right @ 600kPa (Canadian car) and DIC says it was 888 kPa/129 P.S.I. ....... now I assume faulty gage but has anyone else had this problem and it was something else such as a sensor, fuse, sending unit, etc. ? ........as always, thanx in advace for any insight you may give
Received 19,391 Likes
'20-'21-'22-'23-'24
Yes, it sounds like the oil pressure sending unit has gone bad in your car. There are a lot of threads and videos available to help you out on this problem. Use the search function and enter oil pressure sensor and you should get quite a few hits.
1/4 mile/AutoX
I recommend re-locating it so it's out of the hostel environment and easier to change !!
here are some files if you are so inclined !!
Gary Collins (01-04-2017)
When the oil pressure sending unit went bad in my '99, it would show 80 psi and read 130 psi in the DIC, with the ignition on, but the engine not started or running!
Jim
Jim
