cats question
cats question
On a stock 98 exhaust as they age and more miles are on them, do they start to deteriorate in a way that they will become more or less or maintain their original restriction?
Thanks guys
Thanks guys
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF,,,,,,,,,,,,,,,,,,,,, they don't over heat and the engine is not running really poorly, they usually just become less effective and then stop being a catalytic converter and more like a filter. Over time they can clog.
IF the engine runs excessively RICH, has a misfiring cylinder/s for a long period of time they can overheat and melt. Sometimes they clog and others they melt, break in to small pieces and the matrix ends up in the muffler
Received 19,407 Likes
'20-'21-'22-'23-'24
Over time, they do tend to degrade in performance and eventually may require replacement.
Having this exact problem now on my '99. Cats clogged. Headers, cold air intake, mild tune. Random Tech hi flo cats with ~ 40,000 miles clogged, destroyed. car would not rev past ~4000 rpm. sounded tired.
What causes this?
What causes this?
Time to stick something in that mid-pipe and hollow those things out, assuming you don't have to pass the sniffer test.
