Needing part # for C5 Z06 transmission fluid fill plug with electrical connection
I'm needing the part number for the transmission fluid fill plug on a 2002 C5 Z06. Mine has the electrical connector on the end of it.
I accidentally broke the electrical connector on the end of mine trying to tighten it.
Thank you!!!
Thank you!!!
To complete this thread and help others if this issue happens here is the part number for this part.
ACDelco 12458118 GM Original Equipment Manual Transmission Fluid Temperature
