Cleaning Plastics/Rubbers Under Hood
Just curious, would it be a bad idea to wipe down the rubbers/plastics/covers/hoses type stuff under the hood with one of those protectant liquids (like ArmorAlll)? Could it potentially shorten the life of these rubbers/plastics? Any I should avoid?
Popular Reply
03-27-2016, 05:22 PM
Received 3,813 Likes
St. Jude Donor '03-'04
Too the OP.. many products use nitrates to clean ... they do clean, but they also suck the life out of the natural oils found in these products making them dependent on the silicone added so you have to use more ( becoming dependent )... skillfully designed by the manufacturers to turn you into a silicone junkie. This did not happen by accident. Armoral was the first product recognized to be a street drug dealer... their products would clean and shine things like dash boards, tires and rubber products, only to find that months later these products were causing cracking, and hooking the neighbor hood kids on their products.. The manufacturers tweaked their products to address this, but they didn't remove it completely...
I would never use an alkaline soap ( and acid anhydride ) on my car's finish, or used an alkaline or silicone based product on my rubber components.
Simple test of alkaline product.. put some in the palm of your hand a squeeze tightly, if you feel heat being generated ( getting warm ) then the product is an acid anhydride. ( Harmful to automotive parts.) Just some tips brought to you for free... proving beyond a doubt that I am not just another pretty face..
Bill aka ET
You can perform a test at home on an acid anhydride cleaner... go get mom's; dishwashing liquid... put a few drops in your hand, and squeeze.. if it does not get hot, its basic anhydride and good to use on your car... you can try liquid laundry detergent to perform this test too. or any liquid product you put on your car.
Bill aka ET
1/4 mile/AutoX
Chadwick's no-sling tire will make rubber and plastic look and feel new
Wheel wells !!!!!
Received 1,105 Likes
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
The Chadwicks looks good though!
[QUOTE=akapounder;1591864746]
Chadwick's no-sling tire will make rubber and plastic look and feel new. [QUOTE]
Best I've used. It cleans the surfaces (removing the grit and grime that over time imbed themselves in the plastic) rather than just covering up the filth...particularly the inner fenders which, when left unchecked, cause your car to look even older than it already is.
The Lizzard
The Lizzard
Not an ad...I do not work for them. I use Griots Engine Bay Dressing. First make sure it is all clean in the engine area. then spray lightly. I wipe it after a few minutes and get an original factory look, some people spray a second time for gloss.
I also use Griots Undercarriage spray for my wheel wells. Frist time i cleaned it all first and sprayed. on my Avalanche I did not clean first but just sprayed. it looked 90% of the cleaned wheel wells, etc.
Received 19,447 Likes
'20-'21-'22-'23-'24
I have used Adam's VRT for some of the stuff under the hood. Does not leave things looking glossy if you apply it then wipe it back down to remove any excess.
Bill aka ET
Bill aka ET
The following 7 users liked this post by Evil-Twin:
Christee (03-27-2016),
grampzmy00 (03-28-2016),
lewislgZ06 (03-27-2016),
olbear1962 (03-27-2016),
Pounder (03-27-2016),
and 2 others liked this post.
Bill aka ET
Bill aka ET
What products do you use?
I am not going to tell you that because.. it then become an opportunity for cheap shots.. I am too old and sick to deal with that " any More " I take pride in my research.. my car could not look any better...don't use silicones or nitrates on your car. You see even That comment " will crank up the users of silicones and nitrates.. many don't know what they are using on their car.. but with a little research MSDS specs, will yield their properties.
Manufacturer design their products to sell... if their product looks good on your car, but it seems to require more and more applications, its sucking the life out of your car. There is a product here, I wont mention names... but people are buying it by the gallons.. Ive never once subscribed to any thread with this product in it... I never bad mouth it.. But I would never use it on my car. MY car looks better than New, and I've never had to buy a gallon of anything to make it look good... The products that I use in a 9 ounce bottle will last me two years and cost me 12.99 a bottle. My car can speak for itself..
The automotive industry has a lot of automotive enthusiasts that can be easily be led around by the nose because they know that many car guys think that more must be better.
Just a heads up
Bill aka ET
Just a heads up
Bill aka ET
Not a garage queen but is 17 years old with 100,000 + miles.
Seats are 14 years old with about 80,000 miles of seat time.. all pictures are recent
Just a heads up
Bill aka ET
Just a heads up
Bill aka ET
1/4 mile/AutoX
That's what I love about Chadwick's , my first winter with the car I had all hoses and a few of the weatherstrips off the car and was going to replace the hoses. Just for the heck of it, I used the Chadwick's no-sling tire stuff on all the rubber and plastic and after it all felt new, soft and pliable !!!
