New C5 Owner
Received 2,709 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Welcome to the C5 family
Pro Mechanic
Nice! Welcome to the asylum...
NCM Lifetime Member
Received 3,939 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23-'24
Welcome aboard, all easy/minor fixes. Looks awesome!
1/4 mile/AutoX
Welcome !!!!! NICE !!!!!
Thanks for the comments and link to the antenna fix. Had to do this on my '96, but with it the ribbon had broken in the reel and I had to replace the entire assembly. Went ahead and took the reel cover off and removed the ribbon pieces and installed the new mast/ribbon...so now I have a spare that goes with the '96 when I sell it.
And question for a new Vert owner; is the hatch supposed to stay up when folding the top down? This one requires holding it up. Is there something else I need to fix here?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Received 19,439 Likes
'20-'21-'22-'23-'24
Great color choice. Good luck fixing the problem areas.
It is unmolested that is for sure; only non stock item that I have found are the tires. Even has a Delco battery in it...which can't be the original.
Clutch and brake fluid both need flushed as they are as dark as can be....uuugghhh!!
Have not check coolant yet.
Probably does not show in the pictures but the rotors are really rusty where the pads do not contact. Will be spending lots of quality time in the garage checking everything out the next couple of weeks along with fixing those items I have already found.
1/4 mile/AutoX
https://www.corvetteforum.com/forums...er-method.html
