[Z06] Best OEM shock upgrade for lowered '03 C5 Z06?
Old 12-22-2015, 10:44 AM
03 Z-oh-6
03 Z-oh-6's Avatar
Default Best OEM shock upgrade for lowered '03 C5 Z06?
I'm concerned with ride quality more than anything. C6 Z51? C6 Z06??
Old 12-23-2015, 04:20 PM
ZZOOM06
ZZOOM06's Avatar
For ride quality probably the C6Z06 shocks. For best performance the '04
Z06 shocks are what I went with.
Jimbo
Old 12-23-2015, 04:22 PM
03 Z-oh-6
03 Z-oh-6's Avatar
Jimbo
Thank you.
Old 12-24-2015, 11:20 AM
95wht6spd
95wht6spd's Avatar
If you have lowered it a lot, you should look at non-OEM.
Old 12-24-2015, 12:52 PM
ZZOOM06
ZZOOM06's Avatar
Mine is lowered all the way on stock bolts. Before I changed the shocks I did have some issues with wheel hop, but no more since I went with the '04 shocks.
Old 12-24-2015, 01:03 PM
2003Evo
2003Evo's Avatar
The best shocks for both worlds (comfort and racing) are the vikings. I have read nothing but great reviews on them, and some say that they are better than DRM shocks. The best part is that they are pretty affordable as well. I personally run the 04 shocks but to be honest i dont see much different from the original 02s I had in the car.
Old 12-24-2015, 07:06 PM
RIKKITIK
RIKKITIK's Avatar
St. Jude Donor '09
If you're lowered substantially or "all the way" on the OEM's, you probably find the ride pretty harsh. The shock bodies on the earlier shocks are too long/tall. Once lowered, you usually end up riding on the shock's rubber "bump stops", rather than the suspension.
I'm pretty happy, make that really happy with DRM's. Good setup on his low speed valving/damping gives excellent ride, nice tuning on the rest of the valving stack great suspension control without the usual over damped harshness too many people seem equate with "control".
Mine's an '02, lowered on Zip kit bolts. The front wouldn't even come down all the way on the stock bolts due to shock body length. Probably the reason the Zip kits get mixed or poor results with stock shocks.
Anyway, a vote for DRM's
(and make sure to have it aligned once you set your ride height)
Old 12-25-2015, 08:49 AM
03 Z-oh-6
03 Z-oh-6's Avatar
Just ordered DRM's!
Also, don't wantto spend a ton of money, so I ordered prothane front and rear sway bar poly bushings, front and rear control arm poly bushings and added the shock bushings from DRM. I'm getting loud creaking and this "overhaul" should solve that.
Old 12-25-2015, 12:15 PM
95wht6spd
95wht6spd's Avatar
I have the DRM's, you will be pleased.
Old 12-25-2015, 02:33 PM
RIKKITIK
RIKKITIK's Avatar
St. Jude Donor '09
Just ordered DRM's!
I'm pretty sure you will be pleased
Old 12-25-2015, 04:35 PM
dbaker
dbaker's Avatar
I have '10Z shocks on my 02Z.Perfect fit.Set was less than $300.
gmpartshouse.com
\db2
caroliba
Old 12-26-2015, 01:54 PM
03 Z-oh-6
03 Z-oh-6's Avatar
gmpartshouse.com
\db2
caroliba
Those were tempting, but my car being lowered, as someone said above, OEM may not be the best replacement.
Old 12-26-2015, 04:31 PM
Sox-Fan
Sox-Fan's Avatar
In case you were wondering about the physical length difference between OEM and DRM shocks (being lowered and all, it matters) there are several threads in the autocross and road racing forum where they are measured or compared.Here is one: https://www.corvetteforum.com/forums...t-upgrade.html
03 Z-oh-6 (12-26-2015)
Old 12-26-2015, 06:50 PM
03 Z-oh-6
03 Z-oh-6's Avatar
Awesome. Thank you.
Old 12-27-2015, 11:47 PM
mountainbiker2
mountainbiker2's Avatar
Better check out this thread.
https://www.corvetteforum.com/forums...port.html:ack:
Old 12-28-2015, 08:55 AM
Sox-Fan
Sox-Fan's Avatar
good thread to refer to, but fix your link. the : ack : doesn't belong in it.
Old 12-29-2015, 07:30 AM
03 Z-oh-6
03 Z-oh-6's Avatar
Originally Posted by mountainbiker2
The shocks in this thread are Bilstein Sports, not DRM Bilstein Sports.. Does the re-valving of the DRM's make a difference in length? I saw another thread where the DRM's did measue shorter than the OEM shocks.
Old 12-29-2015, 08:24 AM
Sox-Fan
Sox-Fan's Avatar
Same body, piston, mounting. Different internal valving for compression and rebound.
Old 12-29-2015, 09:22 AM
JoeJ
JoeJ's Avatar
Whichever shock you go with consider this mod for the rear, of a lowered car. It will help in most cases.
https://www.corvetteforum.com/forums...clearance.html
To Best OEM shock upgrade for lowered '03 C5 Z06?
Quick Reply: [Z06] Best OEM shock upgrade for lowered '03 C5 Z06?
