C5 interior lights won't go out
Old 09-28-2015, 05:38 PM
retire29
2nd Gear
retire29's Avatar
Default C5 interior lights won't go out
The interior lights in my 2003 C5 won't go out so every time I get in the battery is dead. Any idea how to fix this?
Old 09-28-2015, 06:00 PM
Choreo
Support Corvetteforum!
Choreo's Avatar
Are they off when you are driving around at night?
Old 09-28-2015, 06:09 PM
Torch Rot Z
Torch Rot Z's Avatar
Is the interior switch off? Right under the cluster.
Old 09-28-2015, 07:51 PM
MAC5
MAC5's Avatar
Have you switched out any lights to LED's?
Are all the interior lights staying on, or just the map lights under the rear view mirror?
Old 09-28-2015, 07:53 PM
65GGvert
65GGvert's Avatar
Received 3,234 Likes on 2,310 Posts
Make sure you haven't rotated the instr lamp dimmer switch all the way to the end to turn on the interior lights. You can do it with a knee, or cleaning.
Old 09-28-2015, 07:55 PM
pewter99
pewter99's Avatar
Received 1,195 Likes on 704 Posts
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
the **** is the usual culprit
Old 09-28-2015, 08:47 PM
Wallly
Wallly's Avatar
Another vote for "check the ****"
Old 09-28-2015, 10:49 PM
Choreo
Choreo's Avatar
If it is the switch/****, then the interior footwell lights will be on at night while driving the car... right?
Old 09-29-2015, 07:43 AM
retire29
2nd Gear
retire29's Avatar
Default lights won't go out
I had turned the **** all the way, My bad. Stupid mistake, thanks everyone
To C5 interior lights won't go out
Quick Reply: C5 interior lights won't go out
