Goofy clunking sound - from Tech forum
Sorry to post this in both forums (this one and Tech) but it seems that more eyeballs are on this one...so maybe someone will see it...
Here's a weird one for you experts...
When I pull out of the garage and take off down the driveway everything sounds great. I've noticed lately that when I come home and slow down to turn I hear a slight clunking sound. It's hard to pinpoint where it is coming from but it sounds like the front end somewhere.
Does this make any sense? Is there any component(s) that would be prone to rattling/clunking once things warm up from driving?
2003 stock coupe.
2003 stock coupe.
1/4 mile/AutoX
sway bar link ?????
Sounds like wheel bearings...
A wheel bearing can cause a clunking sound?
I've had them go out on other cars before and all I heard was a loud grinding sound. This clunking isn't just one isolated "clunk"...it sounds like something is rattling.
Also, it's not speed dependent. The sound doesn't get worse or better depending on how fast I'm going. It also doesn't happen when I am turning...I hear it as I am slowing down and getting ready to turn.
Could be a number of things, sway bar bushing, end links, etc etc. Best bet get your butt under the car and have a look. Hard to diagnose a "clunking" sound over the internet..Wheel bearinsg don't make a clunking sound like you said not sure why grantv would even suggest that. Something is just loose and you being stock I would imagine it's the suspension components..Lift the car up and inspect because all anyone can do is guess..
I had the front end up a few weeks ago when I was painting my calipers. I looked at the sway bar links and didn't see anything strange...
Did you take the calipers off? retrace your steps and check the torque on them if you did. I would also check the torque on the sway bar bushings and end links..The plastic endlinks probably look like crap so get a really good look/inspect them. Same with the tie rods and bushings...Bust of the torque wrench and get at it. Spray down/rub some lube on all the bushings..Start with the easy stuff first and if you can get the car on jacks and have someone turn the wheel all the way to the left and right while you inspect things under the car while they are turning the wheel..
It's a 2003. Weren't the end links metal by then?
Sounds can be misleading. Better check the rear also. I think a loose rear axle nut can cause a sound like that too. Making the noise when you start to turn is a key point. Not hearing it initially may be a red herring but I would not discount it yet.
I would get the front wheels off the ground and push/pull on the them to see if you can get any motion to indicate a wheel bearing issue. Grab the tires at 3 and 9 and 12 and 6 and do the push /pull using both hands to see if there is an issue.
Check the lug nuts also.
I am having the same issue currently, I can get the same noise when the car is parked by pushing on the top of the tire to make the front end shake and it is a fairly loud clunking noise. I have hotchkis sways with stock ends and z06 springs, Ive been under the car with tires off and cant find anything loose. Thought maybe ball joints or shocks but no clue yet. (04 coupe)
If your front end is lowered then check the height adjustment bolt pads to make sure that they have not worn down to bare metal and are rubbing on the lower a arm.
They may also need some lubrication between pad and lower arm.
Also check the subframe bolts front and rear the torque is 81 ft/lbs. Loose bolts can cause a clunking sound...
https://www.corvetteforum.com/forums...e-but-why.html
