Something isn't adding up
Old 08-03-2015, 12:41 AM
Harley6
Harley6's Avatar
Location: Phoenix (Fall/winter/spring); Seattle (summer)
2015 C5 of the Year Finalist
Default Something isn't adding up
I posted the other day about a 2004 CE that I plan to look at this week. I felt encouraged about a car with, according to the owner, just under 47,000 miles and in very good condition.
He seemed honest enough about a couple of incidents when it was hit in parking lots, and I pulled a carfax that confirmed it.
However, I went back to the Carfax again tonight and under the My Garage page it lists "today's mileage" as 155,248.
Now I'm very skeptical because the last mileage listed on the Carfax detailed history report is 1,348 from when a leaky differential was fixed by the dealership the first year of the car. The only other reports on Carfax are yearly registration renewals, and those don't show mileage.
Any thoughts, theories?
Until I can get confirmation that the 46,000-plus miles as the owner states is accurate, I don't plan to make the two-hour trip to check out the car this week. There are other nice cars out there.
Harley6 is offline
Old 08-03-2015, 02:53 AM
CaseyJones
CaseyJones's Avatar
St. Jude Donor '15-'16
It sounds like the owner is either being less than honest or bought it under deception previously. All the registrations listed all his? How long has be owned it? A little more research may be necessary.
CaseyJones is offline
Old 08-03-2015, 03:02 AM
Harley6
Harley6's Avatar
I've been poking all over the web tonight and have run across a few instances like this -- cars whose last recorded mileage was years ago because there was no other record that was turned in to Carfax.
This is a one owner car and everything else he told me was backed up by the report. The last recorded mileage was 1,300-plus, and it looked like Carfax did the math and assumed that if the car had that many miles then, it should be around the 155,000 mark now if it was driven a similar amount each year after.
Harley6 is offline
Old 08-03-2015, 06:50 AM
DetroitPlac
DetroitPlac's Avatar
Carfax is known to be pretty sketchy when it comes to odo reading and # of owners. It said my car had 8 previous owners, whereas the guy I bought it from had proof that he was the third.
I just use it to make sure that whatever I'm looking at hasn't been in any major accidents (and even then, that's not always the most accurate)
DetroitPlac is offline
chevyorange (06-15-2020)
Old 08-03-2015, 07:46 AM
sfc rick
sfc rick's Avatar
Was the instrument cluster replaced with one that had a lower odometer reading....it happens. Even if it was you might not ever get the owner to admit it.
sfc rick is offline
Old 08-03-2015, 08:24 AM
Sonny71
Support Corvetteforum!
Sonny71's Avatar
Oldtimer
Carfax not the greatest when it comes to mileage, I've seen cases of kilometers recorded as mileage. Good luck with the research.
Sonny71 is offline
Old 08-03-2015, 08:50 AM
JR-01
JR-01's Avatar
Received 1,063 Likes on 805 Posts
Talk to the owner about the high mileage and get his explanation. If he doesn't have any documentation to prove mileage it's time to walk. More than likely a Carfax mistake in my opinion.
JR-01 is offline
Old 08-03-2015, 09:22 AM
bjones7131
bjones7131's Avatar
Anyway to contact the owner prior to your guy who currently owns the car. Can the DMV be of any help?
bjones7131 is offline
Old 08-03-2015, 09:35 AM
formula1nut
formula1nut's Avatar
I expect the Carfax is in error but just do some basic checks....most of which can be done through photos and correspondence.
Does the owner have the maintenance history including oil changes?
If so follow the chronology including mileage when service was performed. How many times were brake pads replaced? 3 or 4 and you know high mileage.
Check the gas pedal and surrounding area. You will be able to tell almost instantly by the wear.
Similarly check the driver's side carpets.
Look at both seats, If 140000 there will be really heavy wear especially the driver's seat side bolster.
If it were me I would drive the 2 hours but photos will tell you as easily.
formula1nut is offline
Old 08-03-2015, 09:40 AM
novasscnc
novasscnc's Avatar
If you have air care it shows the milage
novasscnc is offline
Old 08-03-2015, 09:47 AM
Chicago1
Chicago1's Avatar
have you asked the owner of the vehicle why carfax shows that? how do you roll back a odometer on a c5? Dont think you can..but who knows
Chicago1 is offline
Old 08-03-2015, 09:52 AM
Harley6
Harley6's Avatar
He is the original owner and says it has never required any service beyond oil/fluid changes, which he does himself. There's no paper trail on that.
He did put tires and wheels on it three years ago, so surely that paperwork will show mileage. I'll press him on that.
Harley6 is offline
Old 08-03-2015, 10:00 AM
Macleod52
Macleod52's Avatar
If you get the VIN from him you can call any GM dealership and see what records they have and what kind of mileage it's had. They should be able to tell if there are any discrepancies or if it looks like the mileage was rolled back.
Macleod52 is offline
Old 08-03-2015, 10:05 AM
MikeG37
MikeG37's Avatar
I had a similar Carfax situation with the '99 I bought a couple years ago. It's odometer read 12,3xx when I went to look at, and test drive. I ordered the Carfax that evening and it was showing the mileage at it's last registration, 3 months before, being 21,188. The man I was buying from had all the paperwork backing up the car's odometer reading.. including his tag renewal receipt that showed 11,882 on the same date Carfax listed. Numbers got transposed somehow.
MikeG37 is offline
Old 08-03-2015, 10:06 AM
RiceBurnerZ07
RiceBurnerZ07's Avatar
I would just do a basic look over on the car, with that difference in the miles it should be pretty easy to tell if the car has 150k miles or 50k miles. Paint, seats, shifter **** and other 'known' wear areas could be a pretty clear indicator of the mileage of the car, like previously stated.
RiceBurnerZ07 is offline
Old 08-03-2015, 10:11 AM
Sox-Fan
Sox-Fan's Avatar
How would carfax even derive an odometer reading if there have been no entries in years that would give them a point of reference?
Carfax needs to be taken with a grain of salt.
Sox-Fan is offline
Old 08-03-2015, 10:31 AM
Not4spd
Not4spd's Avatar
Always take Carfax with a grain of salt. Do a google search and you will find plenty of people who had trouble trading in their car or selling due to misinformation given on Carfax reports.
Not4spd is offline
To Something isn't adding up
Old 06-15-2020, 09:20 PM
ConeKLR
ConeKLR's Avatar
Cruise-In II Veteran
ConeKLR is offline
Old 06-15-2020, 09:21 PM
ConeKLR
ConeKLR's Avatar
Happens all the time.
ConeKLR is offline
Old 06-15-2020, 09:41 PM
neutron82
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
5 year thread bump!
neutron82 is offline
Quick Reply: Something isn't adding up
