Removable roof squeak
Is this a common problem? If my 01 coupe goes through a dip in the road or hits a bit of a rut, above my head there is an annoying squeak. [am I spelling squeak correctly?]
What is good to spray on the contact areas for this problem?
Remove the roof, on top of the windshield were the latch attaches there are little rollers in there that should be free to roll. I had to free mine with lubricant. I would recommend not to tighten the latch, especially if it is lexan. I believe that undo pressure can create stress on the roof.
Received 19,438 Likes
'20-'21-'22-'23-'24
If it is a snap, you may need to adjust the fit of the top to the car. Here are some files that might help you out. You could also try some dielectric grease to the weatherstripping to see if that helps.
