Installed Evo 9 MR Seats in my c5z (PICS)
#43
Received 1,261 Likes
I like the evo x recaros better, I'd like to try those in my car if I ever come across a set for a good price
#46
Then there are Recaro Sport Topline's...which have electric adjustments.
Interestingly, the topline's do not have the large adjuster wheel, and so MAY be easier to fit as the back is narrower.
#47
Hi,
thanks to everyone who has documented this, it has been very valuable to me and I'm about to this to my 98 coupe. My question is if I use the stock track/base will the seat height be higher than the stock seats? Meaning will I loose any headroom? I'm 6'4 and I can't afford to loose headroom.
#49
I searched but didn't find anything about the EVO X seats. I think the reclining ring sits a bit higher than the evo 9 seat so it may clear the seat belt better. not to mention its a think its a more modern seat.
in the evo, the x and 9 seats are direct replacements, dimension wise they should not be any larger. has anyone looked into the possibility?
http://www.torquenews.com/sites/defa...?itok=zkDOwAWu
http://imagizer.imageshack.us/v2/xq90/268/5ynw.jpg
#50
Bringing this thread back from the dead, sorry boys.
OP, I am doing almost the same exact install but I am using the 2003 Evo VIII Recaro seats with Planted seat brackets.
My issue is that if I were to bolt the Planted bracket right up to the Evo VIII Recaro bracket & slider the Planted bracket slightly interferes with the slider lever arm (basically it partially depresses the arm, unless you have the seat far enough back).
Essentially, I'm asking did you just bolt your Planted brackets right up to the Evo Recaro seats or did you take the mounting brackets and/or slider mechanism from the stock Corvette seats and then bolt them to the Planet brackets? I am also having an issue with the seat belt buckle bracket. The tab on the Planted bracket gets caught on the Evo Recaro seat belt buckle bracket. Finally, do you have any idea on the hardware (bolts, washers, nuts, etc.) that you used for this install?
If anyone else has any input, I would greatly appreciate it. I have a track day on November 8th and I'm trying to have these installed before then.
Thanks everyone!
-Bill
Thanks everyone!
-Bill
#51
Thanks everyone!
-Bill
Thanks everyone!
-Bill
As far as the seatbelt goes, I cant quite remember what I did. Im 95% sure I used the stock C5 buckle assemblies (I bought a spare set off ebay because I like keeping all my stock parts) and bolted them to the EVO seats using the EVO seat belt bolt and some washers. I think I drilled out the C5 hole for the bolt and may have added a small hole in the EVO seat to accommodate the locking 'tab' that's part of the C5 buckle (prevents the buckle from moving too far one way or the other). I cut the tabs off the planted brackets because as you said, they interfere. Hope this helps!
#52
Driver220,
Thank you for both the above post and the private message. I got my driver's seat installed last night following your directions. I am disappointed that I cut the tab off my Planted brackets (they really are very nice units), but I kept the tab so that if one day in the future I want to put actual race seats in my car I can simply have the tab welded back on. Still pains me to have done it though. I bolted the Planted bracket directly to the sliders on the Evo Recaros and just like you said it fit. You mentioned it was a tight fit in your post, that is an understatement! The adjustment **** on the side of the seat rubs (and not just a little!) against the lower seat belt point on the B pillar. The seat sits forward enough that, again just like you said, it does not interfere with the slider adjustment lever; that was a relief. I also hogged out the hole on the stock seat belt receptacle so that the stock Evo bolt could be used and sit flush against the bracket.
I haven't started / driven the car yet because I still need to install the passenger seat (tonight's project) but I was wondering what you did about the stock seat sensor. I was considering removing the wiring from the stock sensor and swap it over to the Recaro but if it doesn't cause a CEL or any safety issues then I may just leave it the way it is. Any input would be greatly appreciated.
Thanks again Driver220!
#53
Driver220,
