Tiress
I run the Vreds on my 02Z.275/35/18 & 295/30/19.One of the better dry & wet grippers I have used.About $900 set.
It's a good DD setup for me.
\db2
Carolina
\db2
Carolina
opinions on this old topic are as far ranging as your choices in brands
I bought Bridgestone Potenzas last year, put almost 7000 miles on them so far. They are quiet, have a great ride, good grip and are wearing well. They were about $600. I would buy them again.
Received 19,696 Likes
'20-'21-'22-'23-'24
Plenty of options out there, but my recommendation is a set of Hankook Ventus V12 EVOs - great price and a very good all around non-runflat tire.
Regardless, non-run flats are smoother and quieter than any run-flat equivalent.
But I just purchased a full set of Bridgestone Potenza S-04 Pole Positions. They should be going on this week.
I have Continental extreme contact , quiet and impressive grip.. Depends on what kind of tires you need and how you drive.. If you just cruise to the car shows 3 times a year I'd just put the cheapest thing I could find on it, I assume if it still has the Goodyears that came on it that it's not driven much at all
The big improvement will be getting the Goodyears off of the car. You then need to decide how comfortable you are without run flats. Allmost all your tire choices will provide a better ride than what you have. Good luck and let us know what you go with.
